no spark or injector pulse
Old May 9, 2021 | 03:52 PM
Jack bowes's Avatar
Default no spark or injector pulse
Just finished putting a 5.3/4l60 combo in a 56 210. has 58 psi fuel pressure crank and cam sensor test ok. btw I have no ground ouput on the grn wire to the fuel pump relay,are all three things caused by 1 problem?
Old May 9, 2021 | 07:04 PM
Surewhynot's Avatar
What computer are you running?
Old May 9, 2021 | 08:45 PM
Jack bowes's Avatar
Stock computer that has had vats removed by an experienced tuner.
Old May 10, 2021 | 09:59 AM
tblentrprz's Avatar
Pull the schematic diagram for the PCM/vehicle you're using and make sure all the expected power and grounds are good.
Old May 12, 2021 | 04:39 PM
Jack bowes's Avatar
found a disconnected ignition source for the pcm,starts and runs great.no codes. do no have ground signal for the fuel pump relay ???
