Water Temp Sensor
Old May 19, 2021 | 08:52 PM
deelli's Avatar
Default Water Temp Sensor
Trying to test water temp sensor (in dvr sided head)...will not give relay the go for elec fan. Question...in checking pcm, should I be able to signal pcm by using heat gun on a temp sensor plugged into harness? the pcm is a 2004 gm truck...using this setup in a conversion.
Thanks
Old May 19, 2021 | 09:33 PM
Michael Yount's Avatar
Should be able to see a rising reading by heating the sensor/area around the sensor; but I'd be careful with a heat gun. It'll melt a harness in a heartbeat - and you'll get little warning before it's too late.
Old May 21, 2021 | 10:40 AM
deelli's Avatar
Ok thanks...
