Holley term X inputs/outputs
terminator X ls1 99-07 24x EV1 kit
Most of my term x is installed on a gen 3 5.3 and getting to the point of hooking up the inputs and outputs. All I need to control are fans 1&2 which will trigger my GM 3 relay harness I built for my 78 vette with dual fans. It says the stock ecu is setup for fan 1 and fan 2 on grey/red and grey/yellow outputs. Then says Idle input for fan bump on white/blue input I believe. The input/output harness has 8 pins/wires, 4 are white/color and those are inputs and grey/color are outputs.
- can I connect the white/blue idle input (looks for ground I believe) to the fan 1 or fan 2 output (ECM sends ground to activate fan relays) that way when the fans kick on the input is activated and I get a bump in idle speed?
- what are the other 5 wires controlling? It only describes one other wire but I have no idea what the remaining outputs/inputs do. My fitech had terminated plugs and non configurable inputs/outputs so I want to make sure I have everything looked up. I noticed every white and every grey wire have the similar color for each... so grey/yellow, white/yellow, grey/blue, white/blue etc. I’m not a tard with electronics and wiring but there is no diagram in the instructions! If I don’t need them that’s great and I can configure them later if I need to.
Don't connect an input wire to an output wire, you are defeating the purpose of the software.
You can go in and assign the inputs/outputs to whatever function you want as long as it meets the requirements for that i/o (ground, pwm, etc...)
Go into the software in the I/O dropdown. Assign the outputs to Fan 1 and Fan 2 and configure them however you want.
I'm not sure why Holley doesnt say anything about any of the other inputs/outputs in the manual/instructions. It talks very specifically about those 4 (Fan 1 output, Fan 2 output, AC shutdown output, IAC Kick input) only saying they are pre-configured in the base calibrations. I just wasn't sure if any of the other inputs were needed for the startup/running of the EFI system. You know how on the holley HP or Dominator they say it has 4 or 10 inputs and each bank of coils is an input, injectors is an output etc so when you get all the necessary stuff hooked up its really like 1 or 2 extra inputs/outputs that you can configure.
I have HP EFI, very similar.
There is no wire for fans in the harness, You have to use up custom outputs to operate fans. After you choose which of the custom outputs will be used for fans, then you can go into the software and configure the conditions when the fans operate. Holley has a built-in fan configurator in the software where they help you build the fan settings. Don't use it. You can do better yourself by building your own conditions when the fan goes on/off.
The other thing I think you're referring to is AC Kick. It's a software feature where the ECU will momentarily bump the IAC valve if it sees a voltage change on the AC Kick wire input to ECU. It's meant to help the engine from stumbling at idle when a parasitic load turns on, such as AC compressor. I guess you could use it with fans, but most people don't need to. My idle is entirely unaffected by electric fans. Again, there is no wire in the harness for AC Kick, you have to use up one of your custom inputs and assign it as the AC Kick.
I kinda doubt you'll need the AC Kick with fans. What you could do is lay the wire in place so it's there if you need it later. I seeded my harness with several extra wires just in case I came up with new ideas in the future.
So is the AC Kick looking for a +12V rise, or a pull to ground? All your Terminator X custom outputs are grounds, so monitoring an Output is not going to work if AC Kick is looking for a +12V rise. I know the AC Kick with my HP EFI unit is looking for a +12V rise.
On the term X its looking for a ground, so connecting it to the Fan 1 or fan 2 output from the holley will provide the ground. On my Fitech I'm not using any IAC kick/bump... in the internal software the fan 1 and 2 outputs allow the PCM to add IAC or RPM when activated... but I'm using a flexalite variable speed controller that uses its own sensor and harness.I'm not sure why I get the light surging its timed perfectly when the fans kick on and I know the flexalite is not PWM control but does somehow control fan speed to 60% starting.
I suggest you read over the wiring manual:
https://documents.holley.com/techlib...10555rev17.pdf
That particular document is for the HP and Dominator, but most everything is applicable to the Terminator X, with the exception that all Terminator X outputs are either ground side triggers or PWM-, while the HP and Dominator can have high side trigger outputs and PWM+
Andrew
The IAC Kick input on the Terminator X is a 12+ input. It should get activated when the AC compressor is energized. While this is helpful, I find that in most cases it is not necessary, as the IAC and spark timing do a nice job of maintaining target idle speed when the compressor kicks on. The IAC kick is a momentary bump in IAC to avoid a stumble, mostly at idle, when the compressor kicks on.
Andrew
Andrew
Page 27 has the inputs/outputs
https://documents.holley.com/techlibrary_199r11761.pdf
I'm sorry but you are incorrect, I suggest you read the right manual as I have been through this manual multiple times. I have attached a screenshot from the Terminator X reference guide/manual 550-903 as well as a link below so you can refresh yourself on the wiring schematics. I don't disagree however with you and I will prob leave the wire not connected but run out to the same area just in case. All the Inputs and outputs including the IAC kick are ground activated on the terminator X.
Andrew
The following users liked this post:
customblackbird (01-27-2021)
Project GatTagO (01-27-2021)
Sorry to tag onto your thread here, but I think its related. I'm wiring up my Terminator X right now, and working on the I/O.
In the manual as mentioned above, Fan 1 is pre-programmed as a ground on the gray/yellow output 1.
But in the only listing of all 8 I/O that I can find on their website, it says gray/yellow output 1 cant be a ground. So I assume that list is incorrect, but where do I find a list of what these I/Os can be, other than in the software which I dont have anywhere yet.
Thanks
Thanks
Thanks
Thanks
The following 2 users liked this post by Haggar:
BaD AZz Z28 (05-21-2021), Project GatTagO (05-21-2021)
