New ECU
Old Jun 14, 2021 | 09:57 AM
BCNUL8R's Avatar
Default New ECU
I have a new ecu which is programmed for my vin. It came with instructions of a key off/on sequence for the security and key fob programming.
I want to install this and not screw it up lol
Can I install new ecu and start with a read entire then disable vats and write to get around the key off/on sequence in the instructions they sent? Then change operating system to 2 bar sd and write entire again? From there I can copy and paste over all my changes done with my current tune?
Old Jun 19, 2021 | 10:43 PM
Pacer Racer's Avatar
The key on, key off sequence is only to match the PCM to the BCM. Most of the time, I've never had to do it
