Cant get the car to idle after installing a new cam and exhaust
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
I'm looking for some guidance on a 2001 Camaro SS M6. I got the car with a pretty substantial rear main seal leak. The car had been sitting for 7 years so I decided to overhaul all the seals and to do some upgrades. I added a Cam, Sinister 230/236 .591"/.601" 112 LSA Camshaft and Hooker Blackheart headers and the catless Hooker Blackheart header back exhaust kit. I thought I had a good understanding on adjusting the RPM, Base Airflow and Spark, but I cant get the engine to idle. I have watched more youtube then I want to admit (hp tuner, goat garage, chopperdoc181). lots of great info for after I get it to idle. just looking for some advice and help getting it there
Raising the idle RPM to 1000 RPM will make it easier to get to idie, and then you can start lowering the idle speed from there. Set 'desired airflow' to around 13 g/s as well.
Base spark timing around 18 degrees.
When I was tinkering with my idle and return-to-idle, I set it to idle at 1200 with AC on. That way, if I screwed up, I could just turn on AC to hide my mistakes.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm sure that would make it hard to get it to idle.
If you have any fault codes, you'd definitely want to get those sorted out first.
It’s not difficult to get it to idle at high RPM, but most of it comes back to fundamentals when it comes to getting it down where you want it. Also consider porting your IAC out if it’s aftermarket. They are usually pretty small when compared to stock. Stepping it up to 3/8” on my FAST 102 made a world of difference on the Camaro.
