Engine dies when STFT start
stroked and bored .005 over for 403ci
new cam - 236/244 112+3
New heads - TFS 225 CNC Cathedral ports
Fast LSXRT intake w/ 102mm throttle body and long tube headers
around 11.4:1 compression
engine is on a test stand not in the vehicle, but accessories are installed.
I noticed the low mV too - but as soon as the STFT start it surges like its overly rich, which made me wonder if I am getting good readings from the O2 sensors. The mV do rise with the fuel trims though, which I think is what I should expect to see
If my O2 are seeing fresh air, I'm probably as far as I can go on the stand without any engine load. My goal on the stand is/was to make sure the engine started and no major mechanical issues came up, let it go through a heat cycle, and work on the idle.
Haven't changed VE (I thought you needed to read commanded AFR vs actual AFR, and if my O2's aren't reading right OR are being contaminated, that wouldn't work)
MAF is stock, so I didn't change any calibration on that. At idle, I would think it has plenty of range to read correct air flow
Injector data come from deatschwerks website. I did double check that I had the right part number.
