Trimming too much fuel in closed loop
So far with 21 degrees of timing it's at 575 rwhp.
Looking at his log file it's idling at 900 rpm at ~70 KPA. For comparison my 427 with big Brodix BR7s is running a 252/260 duration cam idling at 1000 rpm at ~80 KPA and it idles clean as a whistle in closed loop with ID 1700s with no tip in issues because it's not constantly trying to pull fuel due to dirty combustion from a relatively crappy injector. I would suspect that it doesn't matter how much fuel he pulls out down low, the trims will still go negative and it will just make it idle and recover worse. Putting it in OL at idle will cover this up since it won't be trying to trim fuel but with a better injector it would have no problems running in closed loop at idle.
