Trimming too much fuel in closed loop
Open loop is pretty good but in closed loop it trims too much fuel off both banks and causes a bad stumble under load and the car goes super lean on the wideband.
Ideas? I'm attaching the scan file and tune.
fwiw, mine idles fine in closed loop with 247/253 cam, as above tune it open loop for best timing and vac and then soften up the corrections. it starts to slip a couple % but i think that has more to do with o2 sensor placement
You might want to check with the injector vendor about which values to use, if you are NA and/or if you have an aftermarket FPR and how to set up it for NA since it's not seeing any boost.
So where in HP Tuners do I make that adjustment to ask it to only go closed loop above 2000 rpm? I did a search for hybrid tunes and can't see this anywhere.
I agree. It idles fine in open loop. Itr's only when it starts to look at the stock O2s that it goes hairy. I just got home. I'll do some datalogging as soon as it stops raining.
http://www.silveradoss.com/forums/to...sing-hptuners/
There's a section on big cams in bold that talk about setting it up.
I'm going to copy and paste it here so we can find it here too.
After I had my base airflow pretty well dialed in, fueling appropriate and timing where it should be and re-enabled my LTFT’s… it all went to hell. My fuel trims would just dump the max amount of fuel (+25); the motor would shudder, misfire and smell very rich with heavy soot on the exhaust openings. Keep in mind that positive fuel trims are dumped on top of your Power Enrichment at WOT as well and I certainly didn’t want all that extra fuel at WOT. I should have figured this however I didn’t realize it would be this bad. After refusing to believe just the overlap and the headers would cause this bad of a false lean condition (and subsequent maxed + fuel trims), I confirmed I had no air/exhaust leaks. Now I needed to find a way to keep my fueling stable during idle. I figured I had the choice of going full on Speed Density or do a Hybrid Open Loop approach. Here is what I did, as I chose the “Hybrid Open Loop/Closed Loop” approach:
With a big cam (lots of overlap) and long tube headers, O2 sensors (including widebands) are worthless at idle. I had two approaches that I tried. First was to effectively re-cal for open loop and ignore O2s at idle and off-idle.
Disable closed loop at idle and part throttle by setting PE TPS vs. RPM to 0 from 0RPM to 1200RPM inclusive. This forces Pe mode at idle (and subsequently Open Loop) and ignores the O2’s[/b]
Set Pe enrichment to 1.0 from 0RPM to 1200RPM inclusive. This “prevents” any Pe mode fuel enrichment to occur.
Set columns 68*F through 230*F in your OL F/A vs. Coolant Temp vs. Map to 1.00 (one) up to the Map value you saw during your idle scans. For me I have a 1.00 in all cells from column 68*F – 230*F and 20-80 kPa inclusive. (HPT > Engine > Fuel Control > OL/CL > Open Loop > Eq Ratio).
Set Pe enable to a value lower than what you see at idle (look at your previous idle scans), I set mine to 50kPa and see 75-76kPa at idle (HPT > Engine > Fuel Control > Power Enrichment > Power Enrichment Pe Enable tables). In the same group of tables, set the Delay RPM and Enable Torque to Zero. I also made sure there was no “adders” adding fuel such as “Add vs. ECT” and “Add vs. IAT”. Doing all of this ensures you will actually be in Pe Mode and subsequently OL at idle.
Disable STFT Open Loop (HPT > Engine > Fuel Control > OL/CL > Open Loop > STFT Open Loop).
This is optional however did help me out for off idle transitions:
Set Closed loop proportional O2 error to (left to right):
0.06250 0.06250 0.06250 0.06250 0.06250 0.06250 0.06250 0.15479 0.18750 0.21484 0.24023 0.27002 0.27979
Disable DTC codes P0131 and P0151 by setting the code to “3- no error reported” and be sure to have the SES box checked. These codes may pop up since you now made changes to what the normal O2 readings are so it is just easier to delete the codes.
Save the changes and Flash the PCM with the new settings.
Is he referring to the HOT and COLD tabs under Power Enrich>Throttle?
The 80's are totally different than the 60's at idle. The 80's are horrible at idle compared to a good injector. We run FIC 2150's in a bunch of builds and I can make them idle like stock in closed loop.
It was raining yesterday and I'm on MT drag radials so I didn't do any logging. Hoping to do some logging tonight.
I made changes to the tune as ddnspider recommended. In the HOT COLD tabs under THROTTLE I zeroed it out till 2000 rpm. In the EQ Ratio gas table I made everything 1.0 from 0 to 2000 rpm (This equates to stoich as ddnspider mentioned).
Let's see how that works.
The other issue I'm having is I never see knock because I'm using ICT Billet relocation blocks. They desensitize the sensor too much. So I'm debating either increasing the gains on the KNOCK SENSOR GLOBAL GAIN table by doing the following or just simply drilling the block and mounting the knock sensors directly to the block:
Anything else you guys think I should change?
Not sure why the wideband isn't working. Might be a broken wire somewhere. Gauge works fine. I'll take a look tonight.
It stumbles a bit when you first hit the gas and the wideband jumps to 17 but half a second later it's fine.
