NO VSS signal
Old Jul 27, 2021 | 09:58 AM
Hammer31's Avatar
Default NO VSS signal
Please I have tried all I can think of. I have no speedometer and truck wont shift into anything higher than second gear.
I replaces both VSS on the transfer case is there more? Any ideas?
2007 Tahoe LT 4wd
Old Jul 27, 2021 | 10:09 AM
Is there one on the tranny?
Old Jul 27, 2021 | 10:35 AM
Hammer31's Avatar
Not that i can see from laying under the truck.
Old Jul 27, 2021 | 11:15 AM
pdxmotorhead's Avatar
Which transmission? Which Transfer case? has the trans been swapped recently?
Old Jul 27, 2021 | 12:04 PM
Hammer31's Avatar
Yes i had a new tranny installed about 3 months ago...4l65e i believe it is. transfer case is stock
Old Jul 27, 2021 | 12:09 PM
Hammer31's Avatar
Truck ran fine for last 3 months...i was in a drivethru and when i went to pull out it stuck in 1st gear. I can manual shift to 2nd but that is it. D feels like neutral unless in step into it and then ill get 1st or 2nd.
Next day i realized speedo was bouncing around so i changed the two VSS. Then i changed the ignition switch since it was going and a cheap try haha.
Old Jul 28, 2021 | 09:54 AM
Hammer31's Avatar
Found a third sensor at the tail going to front driveshaft but it didnt fix it...im wondering if there is a 4th somewhere on tranny itself????
