Spark no fuel ,pump cycles though
I see that frequently when I clean injs out of junkyard engines.
What's your Technique for freeing them up
I pull the filter baskets, and try to see if they will operate. If not, a solid rap w/ a screw driver handle.
I also put them in the ultrasonic bath, heat it, and run them.
Some can be soaked, then hit with air, from the nozzle end while powered up.
It's hit miss.
It's hit miss.
