E40 T42 4L80e conversion - What's the current verdict?
I have the E40 PCM and the T42 TCM. I do not know which OS either have, though I plan to get HP Tuners at some point.
I've read countless threads here and on HP Tuners forums... but the last posts are from a few years ago and there seems to be 2 main methods of making this work.
I have read about buying a harness from one of several companies, and I have read about just re-pinning the original harness.
I have read about segment swaps between matching OS TCM's, and just swapping with a 4l80e T42 TCM, and every combination of the above.
I have even read recently that no one has actually gotten this combination to work, but also read that member slow67 was very knowledgeable on the topic, however, he hasn't posted here in almost 4 years.
Has any proven, yet simple solution come to light? Please talk to me like I'm 10 years old and explain my options LoL Thanks in advance!
Also it seems the 80e front speed sensor must be hooked up too, but I have never seen which pins on the E40 they hook up to ( i think it's pins 22&23 on the E38 PCM).
In the past when I attempted this, I could flash just the TCM and the trans would run and shift, but it would not run CORRECTLY. Meaning it would lock up the TCC almost the instant the car started rolling.. .Various attempts to fix that issue resulted in a BRICKED PCM. Then, on the next one, I flashed the TCM and the PCM with a different operating system (one that WAS paired with a 4L80E from the factory) and then the GTO WOULD NOT START requiring me to flash the original OS and TUNE back onto the car to get it to start.. Then after a few more attempts-BRICKED PCM.Then on a T-blazer... this could take a while.. My experience has been that flashing these specific vehicles IS different than all other years/models of GM/GMC vehicles. If I'm wrong... Tell me what I'm doing wrong.. Or, let's let the OP brick his PCM and then we can all have a discussion about the right way to do it.. That seems to be how I learn everything with HP Tuners-AFTER I brick a PCM then someone pipes up and says :"oh you gotta do it this way"...
In my case I can just scrap that plan and go standalone because it's going in a project car. I actually just had a 2001 Suburban with DBW fall into my lap for just some labor. So I'll have all the gen 3 wiring and stuff from THAT vehicle instead. It's gonna be a whole heck of a lot easier to get a 4L80e behind those factory electronics! But just to make things interesting, I have to look into an X-Link because I want to keep the intake and larger throttle body from the LH6 if possible.
Anyhoo, after days of research and hours of reading and videos, this is too difficult of a path for me to attempt. Even if someone gave me step by step instructions guaranteed to work, it's still so much hassle. I have a computer and harness now by a miracle, so I'll go the easy route
Maybe include gas pedals too.
I rarely tune these, but that would sure be handy for helping folks out.
Ron
I think the easiest route to do these conversions-on the T-blazer SS and the GTO, is to look up the service # on the PCM, and then find another operating system that came from the factory that was paired with a 4L80e that is compatible with your service #.. THANK YOU Minitryker for that information!!! Then, if we knew which SERVICE #'s were capable of working with WHICH operating systems, we could then flash both the TCM and the PCM together at the same time. That would be the only way to work around this problem.. Well that and an understanding of what "SPS? is, and if we, the end user at-home-tuner, have the capability to flash that.
Until more is known about doing these swaps I will stay far the "F" away from attempting to 4L80E swap these vehicles. The OP was WISE to ask up front about this as he has probably saved himself a bunch of time, money, and frustration. I think the OP mentioned swapping to an older PCM/TCM arrangement thereby avoiding all of the drama. Very smart on his part.
