Terminator x max
Old Oct 25, 2021 | 07:28 PM
Rob152's Avatar
Default Terminator x max
On the terminator x max can you run a throttle cable or do you have to run throttle by wire. Also can you use a 400 transmission and it work fine? Thanks
Old Oct 25, 2021 | 09:52 PM
LLLosingit's Avatar
Yes you can run a cable throttle body, You just need the correct harness or make the proper changes to the harness you have so you can control the IAC on the cable throttle body. Yes on the 400 turbo, It won't control it obviously but the trans you choose has no effect on the ECU running the engine.
