Need Help with diagnosing Single Cylinder Misfire
Hi All,
I recently noticed a rough idle -- with intermittent exhaust backfires -- on my 2001 Firehawk.
At one point I also received a Flashing Check Engine Lamp along with DTC P0302 -- Misfires on Cylinder # 2
It seems as though the engine smooths out when taken above 1,200 RPM. However, I haven't scanned the engine when it is at this elevated Fast-Idle condition.
Drivability, other than idle, to include even WOT, doesn't seem to have any issues.
I have scanned the engine multiple times from a cold start ( Ambient about 60 F ) and noticed that the misfires do not begin until several minutes after the engine has been running.
Each time I have scanned it , the misfires on Cylinder # 2 begin about 7-8 minutes after start. It seems as though the engine goes into closed loop within 2 minutes of initial start as evidenced by the PCM beginning to report STFT values other than zero.
No other Cylinder shows any misfires - ONLY cylinder # 2
I noticed that during the first few minutes of operation, while there are no misfires, the STFT ( Bank 2 ) values hover around 0 to -6. The STFT during this period are ALWAYS NEGATIVE.
After 7-8 minutes, I begin to see reported misfires AND I see that the STFT ( Bank 2 ) values are now ALWAYS POSITIVE.
Sometimes, after 8-10 minutes of misfires, the STFT will begin to go NEGATIVE and the misfires will then stop.
I have a Wideband O2 gauge that seems to validate the Lean ( PCM responding with POSITIVE STFT corrections ) during the misfire events. I realize that a misfire can appear as Lean to the O2 sensors as the unburnt oxygen hits the sensor.
Please look at some captured data I took during one of the Cold-Start data-logging events. This data is representative of several cycles I have scanned from a cold start. i.e. it is somewhat repeatable
Some more information to help with everyone's diagnosis:
Thanks to all for looking at my issue and suggesting a course of action.
Bob
- Fuel rail pressure is measured to be 57 PSI at idle and 55 PSI at WOT
- LTFT for both Bank 2 ( Cylinder # 2 ) and Bank 1 are at Zero ( 0 )
- Idle Vacuum is steady ( even when misfires are present ) and is 21.7 In Hg ( I'm @ 3,000' )
- New Plugs and wires about 20,000 miles ago - this is when Long Tube Headers and a Cat-Back were installed
- Engine is STOCK except for wrapped Long Tubes and Cat Back - (Exhaust system has NO CATS)
- Engine has 169,000 miles and uses "about" 1 quart of oil every 1,000 -1500 miles
- Engine has been running fine until this recent idle issue - nothing has been changed on the engine since the Long Tubes were installed 20,000 miles ago.
Bob
Seems like it's heat related. Try switching the plug, then the coil one at a time. If the problem persists after both of those tests, it's probably a loose connection feeding the coil or (I saw you replaced the plug wires), but it would be worth checking at that point.
Nick
Nick
The following users liked this post:
FireHawk#139 (12-17-2021)
Nick
Nick
I'll go through a Coil - Plug wire - Spark Plug swap with # 4 ( 1 component at a time ) to see if that helps me narrow down the issue.
Look for me to Post back my findings tomorrow night.
Also - if my calculations are correct ( see attached Word Doc in my first post above ) I am misfiring almost 50 % of the time in Cylinder # 2 during my Cold Start scanning.
Why is this high of a Misfire rate NOT reported by the PCM as a DTC ?
Seems that the Misfire Counters in the PCM have a very high threshold before setting the DTC.
Does anyone know the criteria ( # of Drive cycles - number of Misfires - etc ) before the PCM sets the Misfire DTC ( P030X ) ?
Thanks again for feedback !
Bob
It's FIXED !
Well... I simply swapped Cylinder # 2 Coil and Plug wire with Cylinder # 4 Coil and Plug wire.
The Coil connectors seemed clean and were fully seated when I took them off.
Plug Wires seemed fine with no evidence of carbon arcing etc.
And... after 3 -- 18 minute Cold Start cycles over the course of several hours - NOT A SINGLE MISFIRE !
I then took the vehicle out for about 30 minutes of "spirited" driving along with several stop-light idle cycles.
Absolutely NO Misfires ( YES ! )
Thanks for your suggestion of simply swapping the Coils and Plug wires.
Oh, even though the coil connectors were fully-seated and the connector pins looked clean, I did spray contact cleaner on both the pins and sockets of each coil's 4 pin connectors.
I am a Happy Camper.
Thanks for the help.
Bob
Bob
G Atsma (12-15-2021)
