DIY e85 sensor display
Old Dec 18, 2021 | 09:10 AM
aknovaman's Avatar
Cool DIY e85 sensor display
Functional but fuel temp code needs work. I can post the arduino code once I get temp numbers working accurately. Total cost is under $10 excluding sensor. Wanna be really cheap and you can get sensors for $10 at a salvage yards. My description of how the code math works in vid was incorrect.
Old Dec 18, 2021 | 09:46 AM
aknovaman's Avatar
Code is a work in progress and will edit as I improve it. I prefer to keep my code simple as possible.
Code:
#include <Adafruit_ST7735.h> // Hardware-specific library
#define cs 10
#define dc 9
#define rst 8
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
Adafruit_ST7735 tft = Adafruit_ST7735(cs, dc, rst);
const int pulsePin = 7; // Input signal connected to Pin 8 of Arduino
int pulseHigh; // Integer variable to capture High time of the incoming pulse
int pulseLow; // Integer variable to capture Low time of the incoming pulse
float pulseTotal; // Float variable to capture Total time of the incoming pulse
float frequency; // Calculated Frequency
void setup()
pinMode(pulsePin, INPUT);
tft.initR(INITR_BLACKTAB);
tft.fillScreen(ST7735_BLACK);
tft.setRotation(1); // rotate 90 degrees
tft.setCursor(5, 0);
tft.setTextColor(CYAN);
tft.setTextSize(3);
tft.print("E85%:");
tft.setCursor(5, 70);
tft.setTextColor(MAGENTA);
// tft.setTextSize(2);
tft.print("Temp:");
void loop()
pulseHigh = pulseIn(pulsePin, HIGH);
pulseLow = pulseIn(pulsePin, LOW);
pulseTotal = pulseHigh + pulseLow; // Time period of the pulse in microseconds
frequency = 1000000 / pulseTotal; // Frequency in Hertz (Hz)
tft.setCursor(10, 25);
tft.setTextColor(YELLOW, BLACK);
tft.setTextSize(5);
tft.print(frequency - 51.1, 1);
tft.setCursor(5, 100);
tft.setTextColor(GREEN, BLACK);
tft.setTextSize(2);
// tft.print((((pulseLow) / 1000) * 40.25) - 81.25); //display fuel temp in C
tft.println((pulseLow / 1000 * 74.25) - 114.25,1); //display fuel temp in F
Old Dec 23, 2021 | 08:13 PM
nocooler's Avatar
Nice - I built one a few years ago, but never ended up using it.
Old Dec 24, 2021 | 12:48 PM
rpturbo's Avatar
This has always looked interesting to me. I've never done anything with Arduino. Not sure I have the patience for it, but I love seeing the creativity guys have.
Old Dec 28, 2021 | 01:12 PM
MaxKreee's Avatar
Damn I think this is the first custom gauge I've ever seen. Cool set up.
Old Dec 28, 2021 | 06:37 PM
aknovaman's Avatar
Another example. I can change the font to make it more smooth.
Old Jan 6, 2022 | 11:18 AM
AwesomeAuto's Avatar
I wish I had more time to dedicate to my old Arduino projects.
I ended up selling my arduino powered engine dyno, fuel injector flow bench, and wideband AFR visual grapher (for carbed engines) last year when my youngest was born.
Good work though, this is really some quality stuff.
