When tuning what Duty Cycle would FAST 33lb Fuel injector be using in a 402 ? 90+ % ?
I don't know about being 100% but I'm sure with those small injectors you will be close. There is a formula that can help calculate fuel system requirements, but I don't have it. Try the fuel section.
The equation to calculate the flow rate due to fuel rail pressure change is:
new flow rate = old flow rate * SQRT(new pressure/old pressure)
For example, 33#/hr injectors @ 45psi, will flow what @ 58psi:
new flow rate = 33.0 * SQRT(58/45)
new flow rate = 33.0 * 1.135
new flow rate = 37.5 #/hr
I thought that I was cutting it close with FAST 36#/hr injectors that I purchased. I am only guessing, but I would think that you will be 100% DC at WOT. (36#/hr @ 45psi = 40.8#/hr @ 58psi)
When I'm done with my SD tuning, I will run my engine above 6,000 RPM and be data logging. I can give you a better answer then concerning my DC.
FAST doesn't have a 33lb injector, they go 24,36,42,55,60,65,83,95,160 lb/hr. Are your injector bodies white in color?
Edit: They do have a 33lb/hr injector specifically for the LS2. Is this what you have?
Assumptions:
1. Naturally aspirated 402 ci engine
2. 525 BHP peak
3. 6000 RPM HP peak
4. BSFC of .46
5. Proposed injector size: 33 lb/hr @ 4 Bar
With these assumptions, you will be at around 91% duty cycle using the proposed injectors. You would need a minimum of 38 lb/hr @ 4 Bar injectors to stay under 80% duty cycle.
See the calculation below:
If you disagree with any of the calculation please let me know and I'll correct it.
The following users liked this post:
G Atsma (01-06-2022)
