Codes after heads and cam swap
Old Mar 14, 2022 | 10:48 AM
King23's Avatar
Default Codes after heads and cam swap
Hey guys just did a heads and cam swap on my 98 formula after sending the pcm in for a mail tune to get it running I started it up and it's throwing code p0118 and p0122 I have changed both sensors as well, the temp sensor on the cluster isnt working either. I'm thinking a wire could have got damaged in the swap possibly a ground wire any ideas?
Old Mar 15, 2022 | 08:13 AM
pcguy's Avatar
Probably need to verify the damage and fix it if necessary...
Old Mar 16, 2022 | 09:41 PM
King23's Avatar
You think its a damaged wire as well?
Old Mar 17, 2022 | 06:48 AM
pcguy's Avatar
Sure; bc you seem to have reason to believe that. What's the reason?
Nick
Old Mar 17, 2022 | 08:33 AM
98CayenneT/A's Avatar
For code p0118 make sure you plugged the coolant temp sensor back in on the drivers side head
Old Mar 17, 2022 | 08:36 AM
Code p0122 try a TPS relearn procedure
Old Mar 25, 2022 | 10:17 AM
King23's Avatar
I have everything plugged back up, reason I'm thinking it's a damaged wire is because the needle in cluster is also dead for the temp sensor as well codes was stating for tps= high circuit, coolant was low circuit. Also tried a relearn on tps still nothing
Old Mar 28, 2022 | 08:08 AM
gagliano7's Avatar
The 98 has the 3 wire temp sensor if i remember correctly so one wire goes to your gauge. It is the wires or the temp sensor is bad. Sometimes a new sensor isn't always good.
Old Mar 30, 2022 | 12:45 PM
King23's Avatar
would the temp sensor cause the the sensor to mess up as well I read on here they was ground together
