P59 A/C Wiring
Old Apr 21, 2022 | 08:07 AM
bb69chevelle's Avatar
Default P59 A/C Wiring
I am doing a swap with a vintage air set up and a factory 411 ecu p59. I am wanting the ecu to turn the fans on based off a/c pressure and coolant temp. I believe that I have to put the 3 wire sensor off of the high side on and wire into the ecu along with a 12v request wire. Does anyone know if this also gives you high pressure safety also. I am planning on letting the vintage air cycle the compressor. Any help would greatly appreciated.
Old Apr 21, 2022 | 09:58 AM
I think a call to Vintage Air would answer all the above questions.
