1998 PCM reputation
I'm not switching to a 0411 or an aftermarket PCM. Am I SOL in trying to optimize the spark tables?
Yes, they seem to have a reputation to Brick more easier than others.
However, my approach to Flashing them is to have a good battery charger on the battery and do not touch anything during the Flash process such as radio, window or open the door. Basically, if you sneeze during a Flash it may BRICK LOL.
This tech is just down the road a few miles from me (KS).
https://www.customecm.com/gm-bricked-pcm-recovery
or
https://ls1tech.com/forums/pcm-diagn...-location.html
IMO, some of us think we are too smart to read directions and wing it not paying attention to the pitfalls for failure mentioned in link above. Uploading an HP custom tune is good example. I reflashed my 98 PCM to an HP custom tune without a hitch rather than let my latest tuner do it who I have never seen read any instructions (his reply to me - "I've been tuning for 20 years and this is always the way I have done it."). So now I have a parked ProCharged 98 Z28 with a $200 Aeromotive FPR that was installed to manage fuel pressure with boost. Problem is - he left the IFR table sloped and didn't trust using my file from FIC for the injector data - he used his own data.
My point is there are shops who claim to be pro's who are NOT after you check their work.
FWIW - a tech bricked my 1998 PCM in 01 by trying to flash it on the bench. But back then there wasn't a very large knowledge base for the LS1 pcm and with LSEdit being the only game in town. So perhaps most of the 'bricked' stories are a decade or more old. They just didn't know any better.
To the OP - you might have to drive a bit to Boca Ratan. Call Dan Maslic at Masport Speedshop.
To the OP - find another tuner. If the worst case scenario occurs and the tuner bricks it, the 98 pcm it can be brought back to life. It's 2022. Technology today isn't what it used to be 10 to fifteen years ago.
I suspect some tuners don't want to waste their time on the 98 pcm because of the limited number of tunes available for the 98 pcm compared to 411 and then use the excuse of the mostly bogus past history of the 98 being easily bricked. To save time they like to copy and paste rather than starting from scratch with the tune. One hour at $150 an hour adds up quickly as profit when instead they can start with a copy and paste tune and save an hour of time.
I'm a programmer. I have hundreds of thousands of lines of code stored in a respository that I source daily rather than retyping the code all over again. That said I don't charge or estimate time for work that I don't actually perform.
