ECM relearn
Old May 1, 2022 | 03:59 PM
LS1 TJ's Avatar
Default ECM relearn
My current project is a 80 Camaro with a L92/4L60E combo dressed to look like a LS3. LS3 intake with 42 lbs injectors.
The car runs but I'm making some tweaks on the rest of the car so I disconnect the battery when I'm done working on the car.
Do you have to do some type of relearn process after I reconnect the battery?
Old May 1, 2022 | 06:55 PM
Pacer Racer's Avatar
Yes sir
Old May 1, 2022 | 07:16 PM
LS1 TJ's Avatar
Thanks for the reply.
Can you direct me to a link on how its done?
Old May 1, 2022 | 07:24 PM
Yeah, you might have to reset your radio stations. Other than that no. The engine will reeducate itself after you drive it a bit
Old May 1, 2022 | 08:58 PM
LS1 TJ's Avatar
Original AM/FM radio/cassette and it works. The car came with Lou Graham tape.
Rumor has it since its an 1980 Camaro I don't have to sport a mullet hairdo. If it was a 1982 and newer Camaro a mullet is a must.
Thanks again for the help.
