2008 6.0 LY6 E38 ECM - Using a manual transmission, will it work?
Hello,
Hopefully I am in the right forum and I apologize if this has already been covered here somewhere.
I have a 2008 6.0 LY6 from a GMC Savana 3500. I have the original ECM and have modified the harness for stand alone operation with a fuse panel to power the engine components. I followed the directions on LT1swap.com to rework the factory harness.
I recently had the engine rebuilt and was scheduled for the Dyno and tune tonight. However, I received a call late yesterday that my E38 ECM won't work in this configuration because I am using a manual transmission. I was under the impression that this ECM could be tuned to run in this configuration but maybe I missed something. I have read that I need an OS from a manual transmission car but that creates more issues like the throttle body and the gas pedal need to be changed to what is in that car. I would prefer to not change the gas pedal because I spent considerable time fabricating a mount for the truck gas pedal.
Does anyone have any experience with this type of arrangement or setting up the E38 to run right on a manual transmission?
Hello,
We haven't even attempted to run. I have heard that it will only be missing the speed signal but I don't know what other issues could arise. I know very little about programing as this is my first swap and I am not confident enough to attempt the tune. However, it doesn't seem like it should be this complicated, that's why I am here looking for input.
It's an 08 so they can still use an MDI with SPS to reflash to a manual OS without the BCM needing to be there. HP Tuners only flashes the main part of the ECM and not the integrated TAC module which needs to match the main program of the ECM so you don't run into pedal/TB/TAC mapping issues. This generally also means you need to run the matching pedal.
Your tuner is not steering you wrong.
