Terminator X Max: DBW LS3 First Start - Won't Idle
Old Aug 30, 2022 | 07:24 AM
MTBSully's Avatar
Default Terminator X Max: DBW LS3 First Start - Won't Idle
Just finishing up my 1969 Camaro with LS3 swap. Holley Terminator X max with drive-by-wire throttle body. Fuel pressure set to 55PSI. Basic rundown is below:
  • 2010 LS3
  • BTR Stage 4 LS3 NA Cam
  • Stock injectors
  • Stock LS3 DBW Throttle body
  • Longtube headers
Ready to fire!
Hit the key again and she sputtered a little and almost fired. Decided to try a little throttle and she roared to life. Ran great as long as my foot was on the pedal slightly. MAN this thing is rowdy with open headers lol. Died as soon as I took my foot off the throttle. Checked all 8 primarys, all hot, so i know we are firing on all 8 now. Was great to hear this thing make noise for the first time in 8 months.
If anyone has any ideas why it won't idle on its own, i'm all ears. Still new to the holley system. Its got a big cam, maybe it just needs more idle airflow. ​​​​​​
Right now the wideband is right at the header collector, which is probably gathering air. Do these systems operate like the OEM systems where the o2 sensors don't affect fueling until closed loop once the engine warms up? Didn't smell super rich or anything. Cant figure out a way to attach my tune file here. Maybe someone can take a look if I can figure out a way to attach it?
Old Aug 30, 2022 | 11:06 AM
minytrker's Avatar
You will need to adjust the DBW settings and open the throttle. Your going to also need to make it run in open loop with no learn with open headers.
Old Aug 30, 2022 | 01:19 PM
MTBSully's Avatar
Thanks. Did some research and a major component it seems to getting the DBW to work is adjusting the "Throttle position vs. pedal position". I assume this is what you mean by DBW settings. I was going to un-check the box for "enable closed loop" as well. Anything else I need to do to keep it in open loop with no learn?
Will be trying this stuff after work today. Thanks for the input!
Old Aug 31, 2022 | 09:37 AM
MTBSully's Avatar
Update:
Got it idling pretty well by cranking up the DBW setting: pedal position vs. throttle position, and also turning off closed loop and "learn". Thanks for the suggestions!
