Struggling to get accurate readings
I've got two logs attached. Log 1 was this morning, about 55-60 degrees, didn't run into too much traffic and got a couple of chances to open the taps.
Log 2 was in the afternoon/evening. Temps reached roughly 85 today and were close to that when I left. Ended up sitting in a lot of traffic (relatively) so I know things under the hood got pretty hot. (just look at the iat's).
What concerns me is in the morning when I reached redline the MAF spiked super lean, whereas in the afternoon when I hit the rev limiter it was rich by a few points. I'm filtering out 5% throttle transients over 100mS, and my cell count is around 15.
Thoughts? Advice?
Last edited by HappySalesman; Aug 24, 2022 at 10:02 PM. Reason: Helps to actually post the logs lol
Right now the VE table is stock. I have the tune set up to where it should read from the MAF only, so the VE table shouldn't be coming into the equation. I plan on tuning the VE table, but the person who "tuned" my car previously had set it up to run MAF only before and I figured I would just continue where they left off.
Curious that the MAF heatsoaking doesn't affect it's accuracy. I would've thought that since the wires are resistance based (and therefore heat based) that the housing/air getting hot would skew the readings.
To get a good derivative, watch my acceleration rate video on how to do that. It’s based on rate of change, aka, derivative, in the case of that video it’s using speed. That can be applied to literally any PID in the tune if you’re crazy enough to log all of that.
Essentially it’s (PID - 1000ms) - (PID + 1000ms)
The period of time is up to you, and I’m also not sure if this will work as an actual filter. Filters are great for a lot of reasons, but I’m highly curious what your math is for determining what 5% is, unless you mean literal, which is probably why you are restricted on data.
LTFTs will remember whatever number they had last at the moment you enter PE. So if at that point they are lean, they stay lean through PE and do affect it. Same for rich. You do have trims off for tuning, correct?
I don’t know why you didn’t respond to my other questions. I’m here to help like everyone else is. Don’t be scared to answer. This is the place to ask before you blow something up. Knowledge is free here brother, don’t be a stranger.
