Holley CAN IO module no 5v
Turned it on and only my trans temp sensor and air tank sensor weren't working, havent checked driveshaft yet. Ran through all of my outputs and everything is good, checked 5v to the tank sensor and had no 5v. So I left it unplugged and started going over everything in the software to make sure it was all in the right places. Come back switch it on and now I have no inputs on the CAN. Unplugged all of the sensors and none have 5v power, they all seem to be grounded according to my voltmeter. I remember thinking my trans temp sensor just works off sensor ground and I have that but it still doesn't work.
So I did some messing around, making sure the module pins were correct and all seated and it's all fine. So I made a jumper and went from my power tap connector and back probed 5v to my back pressure and coolant pressure sensors 5v circuit and every sensor started reading, including the trans temp that doesn't get 5v.
I'm a bit confused with the temperature sensor, but I have no problem permanently running 5v from the terminatorx to the can sensors. I'm just concerned why this happened, the only sensor wires I touched were for the driveshaft. I know the can gets its power and ground over the can circuit and then I assume it creates its own 5v outs? So if it's turning on it should be putting out 5v to the designated circuits? I don't want to hook my ecu 5v to it and it then mess up the ecu some how.
Anyway sorry for long post, just confused and thinking through text. I ofcourse appreciate any thoughts, ideas, or feedback.
I also keep any sensors on the can module grounded through the ground pins. Some are noted as 5v and some are just "grounds" which I would assume would be for higher voltage sensors. I havent used them yet.
as a side note, I have smoked the i/o FET's on a terminator. Not sure how I did it, was fine one day and the next it wouldnt sync. Holley warrantee'd it very quickly, thankfully.
I added 5v from the power tap to only 1 of my can 5v circuits, just teed it inline. And now all of the sensors are working, so all the 5v inside the can module are still connected to each other. The can module just isn't outputing the 5v. It is odd also that my thermistor wasn't working, but once I put 5v on the can 5v out circuit the thermistor started working. The thermistor doesn't have 5v, so it's like the can module couldn't see its resistance unless the 5v output has 5v on it.
Do you know if the can module creates its own 5v? I would assume it does, but irdk. I don't want to have to send it in to holley when it's working perfect now, it also runs 8 outputs that I need lol
re: holley quality... it is what it is. the unpotted terminator cant take the knocks the HP and dominator can. i dont know if the can module is potted or hardened. I would have to assume not given it's price.
it actually kind of amazes me no one is trying to take holley's lunch. they have the plug n play LS market on lock. the UX is pretty noob friendly and theres a **** ton of support. onboard trans and boost control seals the deal for most of us using it.
yes i know very fast people on stock PCM's but they have like 20+ years of tuning and hotrodding under their belt.
but the market is massive and to have only a few plug n play choices is a bummer.
a local subaru guy tells me Link ECU is coming out with a competitor to the terminator. same price point but more i/o's ....no idea what the UX is like tho. if it's megasquirtish, hard pass
Now today same type situation, was doing some idle tuning, turned engine off and made some changes. Fired it back up and noticed my temp gauge just continued to rise way past it normally sits. found the waterpump and fan weren't coming on. Shut it down, waited a second, turned key on and they were working fine.
So it seems like the can module is going crazy at times and not turning on the outputs. I'm gonna try to call holley in the morning and see what they know about it. I'll let you know what happens Doug!
So now we wait, definitely glad I went ahead and got another 1. I'd hate to have it down for however long it takes them. I'll let you guys know what happens.
I'm going to swap mine over to Holley finally, partially because I tune Holley stuff, and well, it just looks a little better if I am running it. I'm hoping I don't have issues, or it will go back on a P59. I love all the capabilities of Holley, but time will tell for me anyway.
I got my new ptc converter in the other week, was adding a brace to my submarine belt and caught the carpet on fire lol. Burnt the kirkey seat cover and most of the console, luckily i seen it was blazing. The carpet was pretty jacked up, this whole car was jacked up, I should start a build thread. I was also wanting to go with a 17" seat instead of an 18" so like most things it worked out. Hopefully the roads dry up and i can drive it tomorrow.
