Battery died while trying to program
the programming was interrupted, scans its memory and does a self check, then tries to restart programming and then I get a Code 6: restart scanner if message repeat call hyper tech ..
Anyone know what options I'm left with? I'm extremely upset with this issue and hypertech isn't even open to call! 😞
please help me, sos!!
So the hyper tech won’t connect at all? If it does, do you have the option to return the tune to the original?
The short the pin trick likely doesn’t apply because the circuit board is no doubt different than the P01 pcm.
I’m sure one of the big tuning shops could rescue it, but you would likely have to send it to them.
Would be curious to see if HPT can read it.
My first child is on the way and wife is out of work, and mine is slow.. This is the last thing I need right now 😞
I'd love for it to be saved, I'd gladly ship it out. I'm going to call around on Monday, have any suggestions? Thanks
