ECU tuning question
Unless there was a particular reason, I wouldn't go back to a stock ECM and tune with HP Tuners vs buying a Holley Terminator X or X max, ESPECIALLY if you don't have tuning experience.
I absolutely hate the "game boy" handheld they have available, even though it can be useful in some instances, but honestly, price it out. By the time you buy a harness, a ECM, HP Tuners and a wideband, your probably not far off from buying a Holley.
Learning HP Tuners is a semi steep learning curve, and getting help is very hit or miss. I have, and tune HP Tuners, and I'm doing it less and less now, just because Holley simply has a really good product, with lots of extra features, and it's easier to tune or change things for the end user if they feel inclined.
This is just my opinion. Trust me, I also have issues with Holley occasionally, but it's not software related or anything.
I just think you should look at all your options before making a decision.
I understand your looking at 2 different projects, and using a stock ECM could potentially make more economic sense, it really just depends on lots of things only you can answer for yourself. On your Camaro project, if you have any thoughts of NOS, or boost, a Holley has you covered on all of those controllers, and also has built in safeties you can setup, something a stock ECM just can't do. Boost, or N20 controllers get expensive, and it's just one more thing.
I also thought I'd mention a few other things. No, you won't need rear O2's to run SD. On a stock harness, it's going to depend on what the harness is from, as far as MAF delete, because the trucks, use the IAT sensor in the MAF, so you would need to split that out, and run a independent sensor, because IAT is semi important, if your using a truck style harness.
You do need to tune it.
It needs CID, a cam choice, desired AF ratio, and you can adjust the timing.
Its very cryptic, little menus and tables on the hand held unit.
His runs really well actually. Although it was painful getting there.
