Terminator x dry nitrous kit wiring.
Old Jan 23, 2023 | 09:23 PM
Chaosftw's Avatar
Default Terminator x dry nitrous kit wiring.
Hello I think i am having an issue wiring in a dry nitrous kit to my terminator x DBW. I can't get the n2o enable light to turn on. On my holley 7 inch dash. The dash has been in for a while I have blinkers and gauges all working on it and the truck has been running for a year with the dash so maybe I have forgotten something.
I have my switch wired to the ground input pin A3 to the terminator to arm the system. I have my nitrous solenoid relay wired to the output pin b3 from the terminator. I have those turned on in the I/O section under the nitrous tab.
My question is should the n20 enable light turn on on the holley dash. when I flip the arm switch on or does it turn on when spraying? Or do i have to enable something in the software for it to send a signal to the dash? I have tested the system to see if it sprays and it does.
Do i have to change the I/O in the main section drop down from the tool bar.
Old Feb 2, 2023 | 04:31 PM
Project GatTagO's Avatar
Make sure that you have the light on the dash configured to display the N2O enable channel.
Andrew
