Map /kpa
Old Feb 13, 2023 | 10:42 AM
Cabguy's Avatar
Default Map /kpa
Asking for.some.one could look at my tune and log file.to see if something could.be making the map.reading to high at idle doing a remote. Tune.and already was told the wrong hole.size.to.be drill out to 5/16 and help would be appreciated thank you
I'll try and post them.when i get home is the hole.size to much ?
Old Feb 13, 2023 | 10:46 AM
You have to post them for anyone to see them.....
Old Feb 13, 2023 | 06:12 PM
Cabguy's Avatar
msmcabguyfile4.hplcabguy2002 truckBen1 (1).hpt
Old Feb 14, 2023 | 04:21 PM
T/A KID's Avatar
Hole size is fine…. You’re idling at 92kpa (key on engine off is 100) hence you either have a massive VAC leak (but since the engine runs and hit commanded, I’m going to say it’s not hitting on a eight… I’d pull Vc and look to see if anything is out of place…
Old Feb 14, 2023 | 04:29 PM
Cabguy's Avatar
Default Map
I'll pull the intake to check the gaskets
Old Feb 16, 2023 | 03:01 PM
LilJayV10's Avatar
The IAC is 150-200. It would be zero if it had a vacuum leak.
The STIT are 18%+
How much have you opened the throttle blade up?
It needs more air. I don't think I've ever drilled a bigger hole in a T/B.
We need more information on the build.
Old Feb 16, 2023 | 03:09 PM
LilJayV10's Avatar
There is no activity on bank 2 oxygen sensor has no activity.
Bank 1 oxygen sensor is dead lean at idle and moves when you snap the throttle, so that one appears to be working.
Bank 2 is dead or not hooked up.
Old Feb 16, 2023 | 03:57 PM
Cabguy's Avatar
Default Tune
The STIT are 18%+
02 5.3 chevy stage 3 cam stock intake 2800 stall everything else is stock tps ill check was 55 and drill the hole.is what i was told to do then move is to 69 ive check no vac leaks thank you
 Michael S. Palmer
Old Feb 16, 2023 | 04:34 PM
LilJayV10's Avatar
open the throttle blade, do a TPS reset. It needs more air. Absolutely no reason to drill the TB.
Old Feb 16, 2023 | 07:47 PM
LilJayV10's Avatar
Because what will happen is, you will end up drilling too big of a hole and you are fucked.
You have to open up the TB a LOT, before the voltage gets high enough to throw a DTC.
To start out, open it up 1/2 to 3/4 of a turn, do a TPS reset and see how it does. If it's still struggling. Open it another 1/2 turn and repeat.
Tuning the VE and MAF will normally require you to mess with the screw several times before it's right. Then you have to tune the BRAF after that.
and you need to fix that 02 sensor.
Old Feb 17, 2023 | 11:15 AM
Cabguy's Avatar
Default Tune
Should replace the throttle I have another stock one.thats not drilled out
Old Feb 18, 2023 | 12:45 PM
LilJayV10's Avatar
At this point I wouldn't. It still wants more air. I'd go ahead and adjust the TB open some. You just won't have to open it as much compared to if the hole had never been drilled.
Old Feb 18, 2023 | 01:23 PM
Cabguy's Avatar
Default Tune
What should the volts be on the tps
Old Feb 18, 2023 | 02:30 PM
LilJayV10's Avatar
dont worry about the voltage. That's not what you are trying to achieve.
open the TB, do a tos reset, see what your IAC counts are.
personally I disable the idle adaptives, but that's just me.
Old Feb 18, 2023 | 02:32 PM
Cabguy's Avatar
Default Tune
Right now there iac counts 112
Old Feb 18, 2023 | 04:27 PM
Cabguy's Avatar
Default Tune.
I'm getting a.p0107 code for the map./ baro low
Old Feb 18, 2023 | 04:31 PM
LilJayV10's Avatar
With the way it's idling I can see why.
Speaking of that, what MAP sensor are you using? What's the kpa with key on engine off?
In that log it's idling at 90'ish kpa, which is damn near impossible.
Old Feb 18, 2023 | 04:35 PM
LilJayV10's Avatar
Has this thing ever ran right or is this a new build?
Old Feb 18, 2023 | 04:39 PM
Cabguy's Avatar
Default Tune
I paid for the motor watch it run out from other truck cave the man half the money he.pulled it then I paid him the rest of the money put I did get the ecm with the motor same motor just had to get it tuned again
Old Feb 18, 2023 | 05:55 PM
Cabguy's Avatar
Default Tune
I ve check everything I can I'm going to do compression check tomorrow the left side is running cold the driver side is very warm I don't know im.at the wall thank you for your help I appreciate it
