Map /kpa
I'm not for sure when they stopped using the 24x in the trucks.
Where is the cam sensor and knock sensors at on your engine?
It sounds like the problem is going to need a lot more indepth than "I just need a tune." I can't tell you how many customers came into the shop only to find out it's going to cost a lot more to fix the actual problem.
Start with the basics, check all fuses, make sure all grounds are hooked up.
You said one side of the engine is cold? I'm going to venture it's the side with the dead 02.
Do a compression test and rule out something mechanical.
The reason you are getting that map/baro code is it's running like complete crap.
