Question about Innovate LM Programmer
Old Feb 14, 2023 | 04:58 PM
NBMTA's Avatar
Default Question about Innovate LM Programmer
I have their gauge connected to analog out #1. In the programming I set 0.00v to 10afr and 5.0v to 18afr but the graph doesn't extend from 0 to 5 but shows a shortened scale. Also at the gauge it still reads 7.35 to 22.39. Is this correct?
Old Feb 15, 2023 | 10:10 AM
OhTwo's Avatar
What fuel have you selected? Different fuels will change the stoichiometric AFR which is the midpoint of the measurements as I recall. I know I set 0 volts to 0.5 lambda and 5 volts to 1.5 lambda and 1 volt was at gasoline AFR.
Old Feb 15, 2023 | 03:31 PM
NBMTA's Avatar
I have it set to 14.7. I have read that it is better to reduce the AFR range to help with tuning. I am using HP Tuners with the Pro input. Not sure how this would help. Thanks for your input.
