This guy says keep original VE values when increasing displacement value
"How to setup a base fuel map for larger displacement LS engines"
He's saying copy the table of VE values and update to your new displacement.
(Increasing Displacement in the software scales up the VE vales, as you probably know.)
Then, he pastes the old VE values back into the VE table.
I'm not understanding. If you increase the displacement value, and the VE values adjust as a result, that is not what is intended by software design?
What is the logic behind changing the VE values back to the old displacement VE values? Help me understand the logic. Is he right or wrong?
Has HP Tuners changed the way it operates since then?
Really though, that sounds very sketchy...never heard of that bug/feature.
Pressure x Volume = moles x constant x temperature
So… what he did was, he increased volume, then decreased the “moles” essentially. He told the PCM that the volume was bigger, but then changed the only variable that we can alter (other than volume that is) saying it was less.
Now, what is the ONLY result this can be? Lean. Like really ******* lean.
Yeah I’m a little drunk but this is a dumbass video. If you would like I can literally demonstrate this exact math and show why this is about the dumbest **** I’ve seen someone post on YouTube.
Also, it’s been a few years since I’ve updated my software, but, I don’t recall the volume change having anything to do with VE. As in you still have to change it manually after the fact. Every scale I’ve ever done you still have to apply the change directly to VE and everything else in the tune. Maybe that part is new. If so, he’s even more wrong because he’s making it even leaner.
Don’t try this at home kids. This video is complete horseshit.
I have NO IDEA why anyone would want to run this, or why you would lower the VE at all for any reason rolling into a fresh build tune. Most guys I know, including me, INCREASE the VE by at least 15% as a starting point just to stay on the rich side. And I say at least. If that **** just got a true 3/4 cam with a 427 bore it’s probably gonna be a 30% increase over stock just to begin. No issues running rich. Big issues running lean.
What he is doing is setting folks up for detonation and/or pre ignitions. If this is a tutorial it should be reported. Straight dangerous. Just saying.
Here’s why he’s wrong:
https://m.youtube.com/watch?v=QVGC9Jydujo
Back in the old days of LS1 Edit the VE table was just displayed using the raw values from the table in the bin file in the format of g.K/kPa which were just numbers in the thousands. Well a lot of people didn't know what that was so HP Tuners chose to format the DISPLAYED VE table data a bit differently to show a percentage that more people were familiar with so they normalized the raw data values against the Cylinder Volume table (VE% = VE value / (178.33 * CylVol)). This is why when you change the Cylinder Volume (Gen3 applications only, they changed this going forwards with the Gen4+) the VE table "changes" on it's own even though the fueling doesn't actually change because the raw values don't actually change in the background in the actual table. For example, if you raise the cylinder volume table by 15% the VE table will drop by ~ that percentage, but that doesn't change any fueling just yet because the raw values in the VE table are identical, they are just DISPLAYED differently in the editor since they are normalized against the cylinder volume table. Do that same test with a Gen4+ file and it will have no effect on the VE table itself, because HP Tuners is not normalizing it against that variable/table anymore because it caused even more confusion like this.
In that first video the guy is just explaining that when going up in displacement one of the quick and easy ways to "add" fueling to compensate for the displacement increase is to just copy the table BEFORE modifying the cylinder volume table and then pasting it back afterwards. All this does is just scale up the existing fueling from before by the approximate percentage change of cylinder displacement, you will still have to actually tune it afterwards. He is not wrong at all and is 100% correct in his method to easily add fuel to the table for a given size increase as a STARTING POINT.
Now to those of you who say that the VE of an engine won't actually change if all you do is change the physical displacement of it you are also very mistaken. This is a different discussion then above, but if you take the same heads/cam/intake/whatever and move it from a 4.8L to a 7.0L I guarantee the VE of that engine is going to change at every RPM/load point.
Personally I’d still increase it further to account for major mods, but yeah my assumption was he was reducing it it stock. Even if raising it it’s not going to be right, since the displacement increase must be added to the stock value to make PV=nRT true. Increasing “V” must be accounted for by also increasing “n” to make the result work out the same. N comes from the VE setting.
Makes me want to go play with it because real world numbers can and do vary for various reasons.
The old 'gen3' code had all been purged at GM when I worked there, so I never got to see this for myself...otherwise I'd have spotted that. Got me lol
My engine is a 377 ls3 block that I used this technique on for a start up tune, but in this video I used a 408 which is what my friend used for his start up tune that worked for him as well. Gave him a starting point that was very close and safe.
The whole discussion has been very helpful and illuminating.
One reason I asked about the video here, is, though I didn't understand the reason for retaining the VE values, your information in the video overall seemed helpful, and it didn't seem like you would just be putting out bogus information.
I'm still re-reading comments to make sense of it all.
The values in this table represent the efficiency of the engine's ability to fill the cylinders with air.
It is used to predict the volume of air entering each cylinder under varying conditions.
The air mass per cylinder can be determined from the VE table using the following formula:
g/cyl = VE*MAP/charge temperature
Ve is in g*K/kPa,
MAP is in kPa,
charge temperature is in degrees Kelvin.
EFILive uses the cylinder volume to calculate the VE as a percentage.
Changing the cylinder volume will change the VE percentages displayed in this table.
