Holley Terminator X Wicked Backfire
Engine specifics:
Forged LS3 4" stroke 4.070" bore
-6 cc flat top pistons, 10.8:1 compression
Naturally asperated, LSXR intake
60 lb LS3 injectors from SEP
Holley 340 lph fuel pump dialed for 60 lbs on a return style fuel setup
1-7/8" long tube headers
I have attached my current config file, as well as a log of a start attempt where a back fire occurs.
I have gone through the startup tips posted elsewhere in this forum, and adjusted my hot idle for 2-3% IAC position via the throttle body (with a TPS auto-set completed afterward, of course).
What could possibly be the cause here? Needless to say, it's rather embarrassing to show off your car to some buddies in the parking lot after you drove it there, only for it to sound like ole cleeters jalapy popping and banging down the street.
Thanks in advance for any assistance or tips anyone can provide!
https://www.dropbox.com/s/y1kxhz4qz7...-0002.dlz?dl=0
https://www.dropbox.com/s/0tfk3mdq00...earn.terx?dl=0
First thing I'd check with backfire is ignition timing during cranking. Timing should be around +15 degrees in the cranking parameters, and Crank To Run RPM at about 400 rpm.
Cranking Fuel should be around 9 or 10 lb/hr hot, and somewhere around 13 to 16 at 100F coolant temp.
If you have cable throttle body then open up the IAC Parked to 80%. You have a big engine and it needs air.
Disable the Fuel Prime Percent while troubleshooting. It's just going to jack up your efforts to dial in the fuel during cranking. After you get things dialed in I'd suggest to keep that number fairly low around 125%. All it does is give your engine a little kickstart of fuel before timing pattern recognition is achieved and normal fuel injection occurs. You shouldn't depend on it for starting, it's only there to help the engine start a fraction of a second quicker. And keep in mind that little shot of fuel happens every time you cycle the key switch on, so it can load up things with fuel if you're turning the key switch multiple times before cranking.
