Camaro 1998 ls1 swap to 2000 pcm .
Old Mar 23, 2023 | 09:10 AM
camarofbody's Avatar
Default Camaro 1998 ls1 swap to 2000 pcm .
Hi
i have a 1998 ls1 camaro i need to change my computer because i have some electrical problems . My question. Is of i wat to do a pcm swap 1998 ls1 to a 2000 pcm i Will Need a 2000 ls1 camaro vin Numbers to program the New pcm and then i need to repin? I see someguys do this swap . Thank you
Old Mar 28, 2023 | 08:37 PM
laytoncamaroz28's Avatar
Follow this for the wiring. Have the vats turned off and calibrate the fuel gauge. You’ll like the upgrade. Especially if you’re boosted
http://www.mrk-motorsports.com/wp-co...o-1999-PCM.pdf
