How many credits?
So even steady state at e.g. 1500 RPM is way lean? How lean?
What all have you changed? You mention a cam, but not clear if you have the turbo and 3bar MAP installed or its coming?
it looks to be 31 degrees now i was going to put it like 12 across it. I do not care if it makes 100 hp and gets 2 mpg just to move it. i will keep it out of boost and shift at like 2500rpm
at idle it is 11.8 not perfect but not damaging above 2 grand it went 15.8 I shut the car down instantly when it shot up.
Also, should be mentioned, the tune repository is just that, a tune repository. I know they look like something that might work, but fact is every tune is unique and that’s just for stock cars. Add mods to the mix and you’re on another planet. Can they get you close? Maybe, maybe not. Look up how well mail order tunes work out. It’s exactly that. Maybe, maybe not.
If you already have the software, you’re like 90% of the way there. The other 10% is you actually learning how to apply it. Check my sig.
I would add that while the Tune Repository can be useful, I have seen very bad tunes in it. I suspect anyone with with moderate tuning ability would avoid it and prefer to start with a known stock tune.
