DIY: Getting data from Holley CAN BUS
Old Dec 14, 2023 | 04:45 PM
  #41
NSFW's Avatar
Originally Posted by LSswap
LMK if you have ideas for projects, even if you don't know how to get them done. I'm curious to see what people would like to see built.
I've been wanting something that fits into a standard 52mm gauge pod and uses a screen like this one with a microcontroller like this one plus a canbus interface. Peripherals optional, I'd be happy with just power, ground, and CAN.
The electronics is a little over my head but if you're interested in doing that part, I'm perfectly happy to do the software part. My main goal is basically to have a unified gauge that just tells me that everything is OK, or which thing is not OK, but there's other fun stuff I'd like to do as well, like a side-scrolling AFR chart. And since the screen supports touch, the driver could swipe through different gauges, which would be neat.
Separately, but relatedly, and simple enough to do on my own, I'm itching to build something that will log a bunch of data from the stock PCM and send it over CAN, using this module from Pete Sonntag (OBDX, LS Droid) and either Arduino MKR or Seeed XIAO for the CPU and canbus stuff. The parts are all here, and hoping to get it working between xmas and new year's since I have the week off.
Old Jan 18, 2024 | 10:20 AM
  #42
LSswap's Avatar
That round display and controller look awesome. That controller looks like it has bluetooth. So now, all you need is to get the data from GM and send it over the bluetooth. The platform I designed supports canbus and bluetooth and there already exists a library for OBDII on arduino, so I don't see a problem getting data from a GM ECM from the OBDII port and sending it to the bluetooth of the round dial displays. If you are already playing with one of those displays and controllers, I can provide you with the hardware to get the info from OBDII and output to bluetooth. I haven't done it myself yet, but suspect it's doable with my new board.
Let me know if you're interested.
Does anyone know if there is an OBDII simulator? That would be the easiest way to get his going.
Old Jan 18, 2024 | 10:22 AM
  #43
LSswap's Avatar
Found this: OBDII simulator
Actually, now that I'm looking, there are lots of them out there.
and there seems to be some free stuff out there https://www.instructables.com/Arduino-OBD2-Simulator/
Old May 14, 2024 | 12:26 AM
  #44
turboesky's Avatar
This is a really cool project. Would it be possible to use this to take Class 2 serial data from an early LS1 5.7 and convert it into Racepak Vnet data? I am trying to use an early IQ3 that doesnt have the built in OBD2 module (street version).
Old May 14, 2024 | 10:25 PM
  #45
LSswap's Avatar
I'm not sure. Maybe this thread has something you're looking for: https://ls1tech.com/forums/conversio...j-1850vpw.html
Old Jul 11, 2024 | 10:34 AM
  #46
crazybenn's Avatar
Hi! but if i plan to use my DIY dash with a termX (not Max) there's no way to read the CanBus? or do i need to buy an external device to make it possible?
Old Jul 11, 2024 | 02:33 PM
  #47
LSswap's Avatar
The hardware I described can read the CANBUS on the termX, but I don't have the list of can messages for the native bus. Some people out there have it. If you get info on the native messages, LMK, maybe I can help you then.
Old Jul 11, 2024 | 02:42 PM
  #48
crazybenn's Avatar
well i can sniff the CanBus via a Teensy 4.0, I can say the first line look like a clock.. i think i found the MAT , maybe i found the CTS but not sure.. maybe the TPS also... 132 different adress! found the "topic" of a line is easy... for the formula, it's a mind blowing task! ... what's happen if i swith the canbus to Racepack instead of Holley... the Term X have only one CanBus port!
Old Jul 31, 2024 | 08:54 AM
  #49
Kippdipp's Avatar
Please post log/trace
Old Jul 31, 2024 | 09:31 AM
  #50
Kippdipp's Avatar
I've disassembled some firmware using Ghidra and found the attached function which is from the 7" Holley display which receives and sends CAN data to and from a Holley Terminator X.. Looks like index 0x90 corresponds to AFR from what I can tell. No idea if the command, target ID and other bits are similar to racepak but if they are then AFR would be 0x1F204000 (with serial masked) on the native bus (I think).
Edit: Found this string that does suggest Holley CAN does run at 1Mbps "sbin/ip link set can0 up type can bitrate 1000000 restart-ms 50 listen-only off"
File Type: txt
Old Jul 31, 2024 | 10:00 AM
  #51
TrendSetter's Avatar
check out pages 91 and up
https://www.nhraracer.com/Files/Tech...ions_Rev10.pdf
is that what youre looking for?
Old Jul 31, 2024 | 10:10 AM
  #52
Project GatTagO's Avatar
Originally Posted by Kippdipp
I've disassembled some firmware using Ghidra and found the attached function which is from the 7" Holley display which receives and sends CAN data to and from a Holley Terminator X. (also found that the native bus likely runs at 500kbps rather than 1mbs like Racepak). Looks like index 0x90 corresponds to AFR from what I can tell. No idea if the command, target ID and other bits are similar to racepak but if they are then AFR would be 0x1F204000 (with serial masked) on the native bus (I think).
The Holley Standard CAN doesn't share the CAN ID or the structure with Racepak. The Standard Holley CAN is 1Mbps.
Andrew
Old Jul 31, 2024 | 10:28 PM
  #53
LSswap's Avatar
Thanks. The is the same data as the original link I provided on the first post in this thread. Unfortunaltely, the original link no longer works. The link you provided points to the same document that describes the racepak protocol. I fixed the link in the first page.
Old Aug 10, 2024 | 02:09 PM
  #54
Kippdipp's Avatar
Take this with a grain of salt but from what I can gather reverse engineering the digital dash firmware, the normal Holley CANBUS IDs are similar to the Racepak protocol and also runs at 1mbps but has a slightly different structure and values for the ID:
Bits 28:28 – Command Bit (=0 for broadcast i think)
Bits 27:25 – Target ID (I think 101= broadcast)
Bits 24:22 – Source ID (haven't confirmed if 010 is hefi like Racepak but pretty sure it is)
Bits 21:11 – Target Serial (used as a channel # index, index #1 is RPM)
Bits 10:0 – Source Serial Number (11 bits)
So assuming the structure above, the CAN ID for RPM with the source serial number masked out (using 0xfffff800) would be 0x14100001.
For the data:
  • First 4 Bytes: This would be the Value field. These bytes are combined into a 32-bit value. I haven't found any evidence of a scale or offset factor being applied.
  • Second 4 Bytes: This would be the Status field. Usage is TBD.
RPM = (RxMessage.Data[1] << 8 ) | RxMessage.Data[0];
Example:
If the CAN message has:
CAN_ID = 0x14100001
RxMessage.Data[3] = 0x0
RxMessage.Data[2] = 0x0
RxMessage.Data[1] = 0x09
RxMessage.Data[0] = 0xC4
uint32_t RPM = RxMessage.Data[0] |
(RxMessage.Data[1] << 8) |
(RxMessage.Data[2] << 16) |
(RxMessage.Data[3] << 24);
Then:
RPM = 2500 RPM
My car is currently not operational or else I'd log and confirm. Anyone have a Holley CAN trace / log they can share?
Also think I found all of the other channel #'s but don't know if they directly correspond to the channel # index, but assuming they do then attached is the full list I found in the firmware.
File Type: txt
Old Aug 12, 2024 | 11:58 AM
  #55
LSswap's Avatar
For the data:
Example:
CAN_ID = 0x14100001
Then:
RPM = 2500 RPM
That looks promising.
Obviously this needs to be bechtop tested and confirmed. I have a Simulator that can emulate all necessary sensors and cam and crank signals to run a Holley on a desktop. I also have a canbus processor that can interface with the Holley to test these codes. I don't have a Holley however.
Old Sep 6, 2024 | 11:18 AM
  #56
exiled350's Avatar
For the data:
Example:
CAN_ID = 0x14100001
Then:
RPM = 2500 RPM
I have a Sniper, functional running vehicle, Arduino, can module, and am very interested in being able to read the private can to drive other vehicle functions. Do you have an .ino for can capture? I can probably get a running log sometime in the next few weeks.
Old Sep 6, 2024 | 01:43 PM
  #57
Kippdipp's Avatar
Try this and provide the Holley data log too.
File Type: zip
Old Sep 6, 2024 | 03:43 PM
  #58
exiled350's Avatar
That's quite a bit simpler than I was expecting lol. Thankfully I bought a bunch of mizu connectors and terminals when I came across this thread a year or so ago, so I don't have to vampire clip my harness. I'll see what I can come up with and report back, If I can get the data direct from the sniper it'll make my other project so much simpler.
Old Oct 17, 2024 | 03:13 AM
  #59
Rgravine's Avatar
Default Digital Giage Cluster
what about using waveshark amd the sniper 2 Bluetooth module to sniff data sent and decode it?
Looking for Sniper 1 amd Sniper 2 CanBus XML if anyone has it.
Old Nov 16, 2024 | 08:21 AM
  #60
Holley just announced that they are releasing the standard CAN protocol.
Andrew
