What ecu for 6.0L, 4L65E and DBC.
What ecu and base file should I start with for an LQ9 with a 4L65E and drive by cable? Bp automotive wiring harness with the 4 flat o2 sensors they recommend. Looking for what ecu I should use and what base file I should look for.
i already have the truck built and up and running so I’m just trying to find the right stuff to use.
Moderator
The basic "411" PCM should be fine. Some ebay sellers of PCMs could probably put a reasonable tune in it for you. This is good if you don't have HP Tuners.
But then you say "up and running" which implies you already have a PCM on it. So not sure what you are really asking.
I recently purchased a $190 LS1 harness for a swap and I was impressed by the quality of the connectors and overall harness.
Give us more info and you will get a better answers.
if you are able to flash the ECU yourself, there are many stock files on the gearhead-efi forum.
0411 (red/blue) would be a great start for a drive by cable swap, but if you already have the harness you're constrained by that.
