)Oil level sensor problem.
Old Jul 29, 2023 | 04:02 PM
curtisad's Avatar
Default )Oil level sensor problem.
Hello all,
I had a wiring harness made by Current Wiring for my 98 Camaro but instead of having it go to a 98 PCM I had it made to go to a 2002 PCM. Since then my low oil level sensor has stayed on. (yes, I checked the oil level myself) I also replaced the oil level sensor to no avail. Also on maybe an unrelated note, maybe not. My oil pressure gauge is reading low and at idle after it's hot the check gauges light comes on.
I'm thinking that maybe a wire got swapped in the wiring harness for the oil level light and possibly the oil pump needs to be replaced. Before I do that I am going to take out the oil pressure sensor and thread in a gauge so I can truly see what the pressure is.
Any suggestions that I can try? Thank you
Old Aug 3, 2023 | 05:42 PM
curtisad's Avatar
Nobody has an answer? Awesome!!!
