IAT issues with E38 pcm
E38 pcm running a 2015 LS3 in a Miata. Using Z06 air intake with ls2/ls3 card style maf with iat built in. The pcm is the one that came with the engine. OS and calibration details all confirm this. Scanner reads -40 for intake air temp. Getting a po113 code.
Things I have done: substituted new GM Maf sensor, substituted known good e38, pinned all 5 wires from maf back to pcm. All have continuity and all go to the proper pins based on 2015 Camaro pin out for e38. Checked resistance on pin E on maf (iat signal) and it showed proper resistance for the current ambient temp.
My last check will be to see is resistance values are correct at pcm side of iat signal wire. What am I missing? Thanks for any help. BTW, this is about conversion number 30, so I have a lot of diagnostics practice.
