I keep getting code P0099 "IAT Sensor 2". Sensor 2???
P0099 IAT sensor 2 - I only have 1 sensor
My sensor is installed on the bottom side of my intake tube close to the 90 degree bend before the throttle body
Suggestions?
I replaced the sensor because they are cheap, but that didn't help any.
I'm guessing it's been tuned at some point because it's a swap vehicle. More than likely that DTC was accidently turned on when they were turning other ones off.
Yes, and I do not see it fluctuating. It rises when I sit at a stoplight and cools back down when I start driving.
Well, to sound like a dummy, what is DTC?
I'm still a little perplexed how you are getting that code if you are using the PCM out of the 02 F body. The only IAT DTC's that are showing in a stock 2002 f body tune(looking at it with HPTuners) is a P1111 and P1112
I don't think the IAT2 was added till the E38 PCM or possibly the E40.
