Rich Bank 1 and 2
As mentioned, the "Startup Enrichment" table could be modified, but note that the table is called "Enrichment", meaning this is normal during startup on these cars.
Now, if you have a burst of black smoke blowing out on startup, you might have injectors leaking into the cylinders; this can be catastrophic if enough hydro-locks a cylinder.
I can't edit your file and reupload without a license for your file. Thought we were able to do that at one point?? I would recommend setting your closed loop enable to 280 across the board so you run in open loop all the time and turn off open loop stft. If it's not super rich you know the problem's in your closed loop tables. If nothing changes try running in SD mode by going into Engine Diagnostics and setting MAF fail frequency to 0. If that doesn't change anything try running in MAF-only mode by going to airflow > dynamic > dynamic airflow and set high RPM disable to 400.
