L99 with pedal/throttle body codes
Old Dec 20, 2023 | 12:43 PM
L99XJ8's Avatar
Default L99 with pedal/throttle body codes
L99 with 6L80 swap into 2002 Jaguar XJ8. Engine and tranny from 2011 Camaro SS. ECM (has been flashed) and harness from Camaro.
Cranks and fires a couple of times.
Here are the codes:
P2127 TPS/Pedal Position Sensor/Switch E Circuit Low Input
P0122 Throttle/pedal position sensor/switch A circuit low
P0223 Throttle/pedal position sensor/switch B circuit high
P2133 Throttle/pedal position sensor/switch D circuit low
So I'm thinking is the pedal or the throttle body. Any ideas before throw parts at it? Way to test pedal or throttle body?
Old Dec 20, 2023 | 07:24 PM
mrvedit's Avatar
Moderator
That combo of codes sounds like a pedal problem. Not all pedals are the same. The 2011 Camaro takes a pedal with part # 22741799. Is that what you have?
Old Dec 20, 2023 | 07:50 PM
L99XJ8's Avatar
Engine/tranny/pedal all came from same donor Camaro.
