O2 Sensor Troubleshooting
Old Jan 1, 2024 | 07:25 PM
uwjberg's Avatar
Default O2 Sensor Troubleshooting
I have a new LM7 swap in my '66 Skylark. Using a new PSI standalone harness and a mail order tune to get me going.
The car is running and driving but smells very rich and the idle is rough. In looking at the data streaming the bank 2 O2 sensor reads a constant .440 or .445v.
The bank 1 sensor constantly changes after a minute or so of idling but the bank 2 sensor stays at .440 or .445. I tried some spirited driving to see if the bank 2 sensor would start working but no go.
I tested continuity for the ground and signal wires and they are good. The pink wire shows 12v with the key on. I put a new sensor in and nothing changed.
What should I be looking at next? Is it possible the tune has something to do with it?
Old Jan 4, 2024 | 01:02 PM
Full Power's Avatar
drippy, slobbering injector, bank 2 ?
What do the spark plugs look like ?
Old Jan 4, 2024 | 05:55 PM
IGN-1A's Avatar
Default Wide Band Default Value
Hi, sounds like your EGO is wired backwards.
The Black wire IS the signal and gray is the return.
Lance
Old Jan 15, 2024 | 12:14 PM
uwjberg's Avatar
Thanks for the reply - spark plugs look ok. The injectors are brand new as well, and the noid light indicates they are all getting signals.
Old Jan 15, 2024 | 12:16 PM
uwjberg's Avatar
Lance
Hi - newbie question but what is EGO?
I compared the wiring for bank 1 and bank 2 sensors and they are wired the same (same color wires in same spots).
Is there something else I should check? Appreciate the help.
Old Jan 15, 2024 | 05:08 PM
B52bombardier1's Avatar
It is a brand of oxygen sensor - sometimes slang for any O2 sensor. See below.
https://splitsec.com/product/ego1-un...xygen-sensor-2
Rick
Old Jan 17, 2024 | 01:33 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
.44x volts is a default no signal to the computer. You likely have a bad connection at the pcm plug, or a break in the wire somewhere. You would show the same reading with the sensor unplugged.
edit-- With any aftermarket harness it is a good idea to make sure the pins are in the correct spots in the plug end at the computer.
Old Jan 17, 2024 | 03:25 PM
LilJayV10's Avatar
Are you using the correct 02 sensors for the PCM you have? IIRC, some of the of PCM's ground the 02 sensors differently.
Old Feb 1, 2024 | 08:10 PM
uwjberg's Avatar
Ok - here's an update:
  • I've confirmed that I am using the correct O2 sensors for the PCM as described by PSI
  • I've verified continuity with all of the O2 wires from the connector to the PCM
  • I checked the pins on the connector against the LT1 diagrams and it looks to me like the connectors are pinned correctly for the PCM
  • Spark plugs all look fine/dry
When I start the car it does idle a bit rough and blows light white smoke, and when I rev it a bit it smells like fuel coming from the tailpipe.
I'm leaning towards a leaky injector in bank 2, but they are brand new injectors. Guess I need to start figuring out how to diagnose that easily (without disassembling the manifold).
Old Feb 2, 2024 | 12:30 PM
Full Power's Avatar
2 quick troubleshooting options=
Swap O2 sensors, side to side, and see if the problem switches banks, ie follows the "bad" sensor.
or:
Install a KNOWN GOOD O2 sensor in bank 2
Old Feb 3, 2024 | 10:51 AM
uwjberg's Avatar
or:
Yeah, forgot to mention I've tried that too.
In as interesting development, I picked up a smoke leak detector and found that smoke was coming out from under the intake manifold on the passenger side (bank 2).
I took it off and repositioned but the smoke still comes out. I'll take it off again tonight and take a straightedge to it to see if it's warped.
That has me a little confused though, because I thought that would create a lean condition, not a rich one? Why would the exhaust smell like fuel if it's running lean?
For reference, the bank 1 O2 sensor reads around .015 while bank 2 seems stuck on .445.
Is .015 lean?
Old Feb 3, 2024 | 02:58 PM
mrvedit's Avatar
Moderator
.015V is very lean.
Technically, O2 sensors don't send out a steady voltage, but a rapidly changing voltage where the average is what you read with a basic volt meter. A fancy scanner or an oscilloscope will show the rapidly changing O2 voltage when it is working. "Stuck on .445" tells us it is NOT working and/or effectively disconnected. @Full Power suggestion to swap the right and left O2 sensors is a good one.
This is looking like multiple problems; I think first step is to get both O2 sensors reading and they will tell you where to go next.
Also, when you say "brand new injectors" where did you get them? (Rare to find any reputable brand new injectors on ebay - they are either cheap replicas or rebuilt ones.)
Old Feb 4, 2024 | 09:56 AM
uwjberg's Avatar
Thanks for the reply. The O2 sensor would start at like .440 and then change to .445 and stay there. Not sure if that's a different scenario. I did swap the sides with no difference, meaning the known good sensor also did the same thing when installed in bank 2. Just really weird that it appears to be pinned out correctly and I have verified it gets power and the continuity checks out for the harness wires to the sensor.
The injectors are a new DW set I got from Summit - I was wary of the eBay stuff too.
I pulled the intake manifold and it was indeed warped out of spec on the the passenger side rear cylinders. Found another on eBay so hopefully that one isn't warped.
While I had the manifold off I hooked the fuel line back on and primed the system and there was no fuel coming from any of the injectors so that seems to rule out the leaking/stuck injector theory.
Old Feb 4, 2024 | 10:08 PM
mrvedit's Avatar
Moderator
Well, at least we know more now: Your O2 sensors are good as they work properly on one side; same side after a swap. And your injectors are good and not leaking.
Not sure if you checked the O2 sensor connectivity all the way to pins on the PCM. If yes, we might have to suspect the PCM itself.
The change from .440 to .445 is meaningless. As mentioned, it most likely will read that even with the O2 sensor disconnected.
I suspect you won't make more progress until you new intake manifold is installed?
Old Feb 8, 2024 | 06:04 PM
uwjberg's Avatar
Yeah, that's the plan now. Intake should get here in a couple of days and I'll see what happens once that's buttoned up. I do have a spare PCM (untuned) I can try to see if that fixes the O2 sensor problem. If I try a stock ytune PCM on my motor just to test the O2 will that hurt it at all? I have cam/headers/larger injectors.
Old Feb 8, 2024 | 07:35 PM
mrvedit's Avatar
Moderator
What size injectors were stock for that PCM? What size do you have now? With bigger injectors it will run very rich. If your fuel pressure is easily adjustable, you might be able to drop to e.g. 40 lbs to compensate for e.g. 25% larger injectors. Just for a O2 sensor test of course.
Old Feb 19, 2024 | 01:44 PM
uwjberg's Avatar
I went from the stock truck injectors to 44 lb/hr. I don't have an adjustable FPR but running rich versus lean at least to test a little bit seems like it would be ok.
Old Feb 19, 2024 | 01:50 PM
uwjberg's Avatar
Update: I got the new(used) intake and it didn't measure out as warped so I installed it. Did the smoke test and it was good for a long while, but then started to leak some smoke around the base of the intake. Not as bad as it was before and it wasn't in the same spot (it actually looked a bit like it was more uniform on each side). That was pretty frustrating to see if I'm honest since I've battled that same issue previously and though I had fixed it.
I decided to start it up so I could see if it was running any differently and it's now in limp mode for the DBW pedal/throttle body voltage. In the couple of minutes I ran it bank 1 was even leaner than before on the O2 but I'm not sure if it really got warm enough to get a good reading.
I honestly had to start working on the rust repair so I didn't burn it down. Maybe I need to try new intake gaskets? This one is a new Felpro which I thought was supposed to be the best option. Not sure if something else could cause the smoke to come out? I followed the right sequence on the intake bolts and did a first pass torqued to 44 inch/lbs and then a second at 89 inch/lbs.
Old Feb 19, 2024 | 05:50 PM
mrvedit's Avatar
Moderator
Is this a sheet-metal intake manifold? I read they are notorious for leaks, especially after a few heat cycles.
A leak is "unmetered" air. While a small leak contributes a noticeable percentage of unmetered air at idle, it becomes a negligible percentage at higher throttle positions.
So if the banks are even at cruising and high throttle, maybe you can just live with it.
Old Feb 19, 2024 | 06:11 PM
uwjberg's Avatar
It's a stock truck intake, which somehow makes it weirder in my mind.
I'll have to tackle this DBW issue and see what things look like when it's doing more than idling in limp mode.
Frustrating that I've been chasing random gremlins for 8 months now. I just want things to work!
I know it will be worth it in the end but holy cow.
