0411 pcm help
Rick
Some platforms have functions that some don't.
Flex fuel being an example. The fbody and a 2002 Tahoe use the same PCM, however the Fbody doesn't have Flex fuel support but the Tahoe does. If you change the Fbody OS to the Tahoe, add the terminal to the correct pin on the PCM, it now has flex fuel.
I have never read(that doesn't mean it's not true)that there are pins on the PCM that are not hooked to the board. I can't see that making sense from a manufacturing stand point where they are producing millions of PCM's, that they would go through the hassle of not hooking up certain pins.
