Holley terminator x max running lean
Old Feb 26, 2024 | 07:19 PM
78_nova's Avatar
Default Holley terminator x max running lean
New to fuel injection tuning so I'd like some input on this. Fired the engine for the first time the other day and it was running really poorly, so after some fuel pressure, IAC, and idle screw adjustments it seems to idle and run much better, but I've noticed that my AF ratio is bouncing between 17-20ish, while my idle target is 13.8. Also it seems like the throttle hangs at high rpm after i let off the gas. Any ideas? Car isn't all the way put together yet so that maybe has something to do with it but I wouldn't think it should do that. Thank you in advance
Old Feb 27, 2024 | 08:50 AM
mrvedit's Avatar
Moderator
More info about your engine and setup would be useful. Is this an LS engine swap, an upgraded SB or what? So here are a couple questions:
Q1 - Is your O2 sensor more than 24" from the open part of your exhaust? I.e. open headers will not give an accurate reading.
Q2 - Did you enter your Injector size correctly into the tune?
Q3 - Does you fuel pressure match what you entered into the tune?
Also no idea what "the throttle hands at high rpm" means, but lets get the idle AFR working first.
Old Feb 27, 2024 | 09:04 AM
78_nova's Avatar
it's a .030 over 6.0 block with ported ls3 heads, trick flow sloppy stage 2 clone, holley 92mm throttle body with accel 48lb injectors. The car has most of an exhaust system on it, definitely more than 24 inches. I'm sure I have the right injectors I put it in via part number, and I corrected the fuel pressure in the tune because I initially had it too high, bust as of right now the injectors are rated for 43.5psi and we've got 44ish pounds of pressure. Ps: I meant hangs, not hands. Thanks for your time
Old Feb 27, 2024 | 09:51 AM
02redchevy's Avatar
Originally Posted by 78_nova
it's a .030 over 6.0 block with ported ls3 heads, trick flow sloppy stage 2 clone, holley 92mm throttle body with accel 48lb injectors. The car has most of an exhaust system on it, definitely more than 24 inches. I'm sure I have the right injectors I put it in via part number, and I corrected the fuel pressure in the tune because I initially had it too high, bust as of right now the injectors are rated for 43.5lb and we've got 44ish pounds of pressure. Ps: I meant hangs, not hands. Thanks for your time
What does your fueling table look like?(preferrably in VE)
Since you said you're playing with the screw and IAC adjustments it sounds like DBC throttle body. What is your idle IAC % currently at?
Old Feb 27, 2024 | 10:51 AM
78_nova's Avatar
I haven't looked at the fuel table yet, as I said I'm new to fuel injection tuning, but I'll see about looking thru the touch display, I dont currently have a working laptop to plug into. IAC is low right now, 0-1 or 2 percent so I know I need to make some adjustments there, I just wouldn't think it would cause it to lean out that much. But I'll fiddle with it a little after work and see
Old Feb 27, 2024 | 11:46 AM
TrendSetter's Avatar
id check that its getting warm enough to go into closed loop and that you havent hit your cl limits yet. it might have corrected as far as its allowed.
Old Feb 27, 2024 | 01:23 PM
mrvedit's Avatar
Moderator
You say the injectors are rated at 43.5 lbs, but is that at 43.5 PSI? Some of the Terminator X specific injectors are rated at 60 PSI. (I just got caught myself on that detail.)
If there were indeed rated at 60 psi, it would exactly explain you super-lean condition.
Old Feb 27, 2024 | 01:33 PM
78_nova's Avatar
yeah I double checked because originally I had it running at 60psi and it didn't like it, dropped it down to 43ish and it ran much better but still lean
Old Mar 6, 2024 | 05:18 PM
Old Buzzard's Avatar
Get one.
Post the tune and a short data log.
Files have to zipped.
Old Mar 8, 2024 | 12:51 PM
LilJayV10's Avatar
I'm guessing you are using the handheld. Does it say CL or closed loop when it's running? It should also show how much fuel it's adding or removing.
It won't start learning till 160 degrees unless it's been changed, but it will go into closed loop and compensate to achieve the desired AFR.
Without seeing a tune and a log, we are just guessing.
Old Mar 28, 2024 | 07:15 AM
epfatboy's Avatar
did you change all the injector data to reflect either 60 or 44 lbs? If I remember the Holley right there is also a rated and running pressure setting too.
Old Mar 28, 2024 | 08:54 AM
Question ??
He's not been back since the beginning of the month....
Must still be looking for a laptop
Old Mar 28, 2024 | 09:18 AM
epfatboy's Avatar
I guess he'll have a few things to check up on when he finds a computer...
Old Apr 7, 2024 | 06:59 PM
78_nova's Avatar
can confirm, still looking to get a laptop hooked up, got one but ecu needs to be updated before I can connect it, hopefully will update tomorrow if I can!
