Knock retard in boost
I thought it might be lean and the wideband was wrong so I added 10% fuel from 4000 to 6800rpm, 127kpa to 255kpa. Still knocks. Latest tune and log attached. Is it time for better fuel? Is there any of the octane booster that is good for checking this? Thanks
I got some octane booster, put it in, and should be about 98 octane now, and has about 1-2 degrees of knock. It switches to low octane table (I think, and spark is down to single digits. Where would you estimate the timing should be . Not having a dyno makes it tough. I guess I will be hunting E85.
There is some burst knock in there also.
Such a blend:
80% 93 octane Mo-Gas
10% Toluene
10% 100LL
would result in ( calculated) 97.4 OCTane.
I lowered the timing on my tune, but I think I need to lower it some more if that's the direction that I need to go.
How the heck did I get by on the GTO engine for so long with no problems?
Thanks guys, I was headed for BOOM.
