Crank relearn
Old Apr 23, 2024 | 06:34 AM
Spankstangs1999's Avatar
Default Crank relearn
Trying to do a crankshaft relearn on my 2005 2500hd 6.0. Issue is it revs all the way to 5500 limit. It should fuel cut at 4000rpm . I've done relearn on multiple other ls vehicles no issue. Reason for the relearn is p0300 and flashing cel at highway speeds only. What am I missing? Thanks.
Old Apr 24, 2024 | 10:28 AM
LS1Formulation's Avatar
I had this same issue on my '06 Silverado, and I had the same problem when I did it. I was using an older Snap On scanner to do it, and I am pretty sure my issue was that I forgot to press the brake down when I did the relearn. Maybe this will help you, maybe not.
Old Apr 24, 2024 | 12:57 PM
wow that's all it took, thanks brother.
Old Apr 24, 2024 | 01:43 PM
You're welcome! Sometimes the fix is a slap your forehead "Why didn't I think of that?" moment, lol.
Old Apr 24, 2024 | 06:59 PM
[QUOTE=LS1Formulation;20553479]You're welcome! Sometimes the fix is a slap your forehead "Why didn't I think of that?" Aint that the truth.
Old Apr 25, 2024 | 09:06 AM
minytrker's Avatar
I have never seen a crank re-learn fix that issue. I'd check intake gaskets first.
Old Apr 25, 2024 | 09:37 AM
you'd be surprised. All of the 5.3 and 6.0 with the issue of p0300 at above 60mph has always been a crank relearn or maf.
Old Apr 25, 2024 | 03:23 PM
It 100% fixed my problem. Was getting P0300 at highway speeds, nothing would fix it. Did the crankshaft variation learn and the code went away and never came back, and that was close to 10,000 miles ago.
Old Apr 26, 2024 | 10:00 AM
minytrker's Avatar
MAF could see see that all day. I have seen bad maf or leaking intake gaskets more than anything.
I would have lost money on that bet. I would have bet it wouldnt have changed anything. That's awesome that fixed it, defiantly going to remember that for the future.
