MAF G/Sec Open Loop Higher Than Closed Loop?
While I’m here I’d also like to ask, is a 0.39% TPS reading at idle normal?
All of those help it idle with less airflow. When the AFR reaches stoich the car goes into closed-loop but that's a side-effect, not a cause.
My current and previous engines needed roughly twice as much air for a cold start as for warm idle so it sounds about right to me. So does the throttle position.
