terminator x v2 boost control not targeting right
i have a log that shows target boost as 12 psi, boost psig is 2.6, domeMap is 122kpa, but Boost Fill Sol DC never goes above 0%. i cant change units on the domeMap to psig so its kpa and all sensors are reading right.
i cant see why it wouldnt be commanding the fill solenoid.
we are still on v2 software and not looking to change to v3 yet.
is there any condition that a target boost being lower than actual boost wouldnt command fill solenoid duty? the vent solenoid activated briefly so the GUI config seems to be 'right' and it seems to be logging correctly.
i just cant find any reason it didnt command the fill solenoid.
its the same tune we had a 4 port working fine but decided to convert to co2 and dual solenoids after the last race.
thanks all, happy to post whatever screenshots are needed
https://documents.holley.com/199r10628rev2.pdf#page32
Boost vs time is specifically for drag racing IMO
but to your point, i am going to try changing it to boost vs rpm tomorrow just in case theres some weirdness going on.
i appreciate the input.
**edit** wait did I see in your original post that dome pressure isn't actually dome pressure?
the confusing thing that i hope is just some overlooked setting is the software is reporting a boost target that is far above the actual boost but its venting instead of filling. i havent tried to troubleshoot any hardware since it appears to be entirely software not 'doing what we want'
Ill see about getting the car updated to v3, thats very good info thank you.
it reads the same as the map sensor in software.
the ecu isnt commanding the fill solenoid even though 'target' is way above 'dome'. as far as the ecu knows the hardware is right but something in software seems wrong. we need to get that part working before verifying the hardware config works.
so if we pretend the car has co2 and its all hooked up right... can you think of any reason the ecu sees 2.6psi at the dome, reports a target of 12psi but is commanding the vent solenoid at 9% instead of the fill solenoid?
i ran it like this a few years back on my wagon and it worked fine. the wagon is still configured this way from a hardware perspective but has a nexus instead. functions well.
hopefully the move to v3 resolves this.
at 2.5psi of boost (112kpa sensor output) it was treating it like 17.5psi. subtracting 100 from the sensor config fixed it.
what made it more fun to figure out was there doesnt seem to be a 'boost error' channel which would have immediately showed the problem. thanks holley.
also i checked the boost control manual and they say "You can use just about anypressure sensor that can be configured in the IO function as long as it has the appropriate range."
if they specify the range somewhere, i couldnt find it. thanks again holley.
