Added 30% and still LEAN.. any ideas?
5.3 L33
trick flow heads
ls6 intake
id1050x injectors
hellcat pump
d1x procharger
speed density with 2bar map
currently open headers and open TB just trying to get baseline but didn’t see much change after 30% fuel increase before attached log
I attached the injector data and changed the data in your tune that needed to be.
It's setup for a vacuum referenced fuel pressure regulator w/ base pressure at 58psi.
The ID1050x flow 109lb/hr at 4 bar pressure.
With a vacuum referenced FPR, the flow rate needs to be the same because the FPR lowers the fuel pressure w/ vacuum to keep the differental pressure the same. In a returnless system, where the fuel pressure is a fixed pressure, the PCM takes care of it.
I'm not sure why the injector flow rate vs voltage was changed. I don't remember ever seeing that table anything except 1.0
I also changed a value in the transient fuel section, normally with big injectors if you don't, it will run rich no matter how much fuel you take out.
The boost PE table needs to be set up. It's all 1.0
That timing table is going to blow your engine up too. That's for a NA motor, and will boost you are going to max out that air mass quickly which is going to put you at 26 degrees of timing in boost.
now it’s full built/balanced bottom with different heads, blower cam, and bigger injectors … and (unhooked) procharger.
trying to get it running for testing purposes right now, not to drive or boost whatsoever yet.
would I be better going back to a stock silverado tune and doing the SD and injector changes?
can I PM you maybe? I can pay
