Reduced Engune Power ( Cheapest RESET ?)
Old Jun 18, 2024 | 04:50 PM
Full Power's Avatar
Default Reduced Engune Power ( Cheapest RESET ?)
Wife's Daily driver has intermittent Reduced Engine Power.
03 Yukon, Bought the rig with a YUGE Spectre intake, Loud mufflers, had a NEW HITACHI Throttle body and pigtail- on inspection, I found a loose butt connector splice to Throttle Body, cut, solder, heatshrink all the connections fixed everything------ for a month..
Wife has just called with a random re-occurrence of Reduced Engine Power.
She does not carry a tablet with HPTuners loaded: Question for the gang here is-
" What is a cheap, reliable easy to use device WIFE may carry in her DD for Resetting occasional DTCs ? "
. Gotta be OBD2 plug n play, wife friendly unit.. ,
Thanks.
Old Jun 18, 2024 | 05:09 PM
Go on Amazon and get a $30 scanner. There are a bunch.
Get one with good reviews and you should be OK
Old Jun 18, 2024 | 07:00 PM
Full Power's Avatar
anbody use this one:
Blue Driver OBD2
?? Good, Bad, ugly ?
Old Jun 19, 2024 | 05:48 PM
CattleAc's Avatar
This is a good idea.
But, why not figure out what's wrong with it, and not worry about her having to mess with it at all...???
Old Jun 19, 2024 | 05:52 PM
I agree with you, that should be first priority, but it is handy to have a small scanner to see AND possibly delete any CEL that might arise.
That's why I said what I did.
