TermX tuning issue
Old Jul 2, 2024 | 07:53 AM
customblackbird's Avatar
Are the injectors actual take out GM injectors or Amazon specials?
Are they decapped?
The reason I ask is, what I'm seeing in the log/tune vs what I would expect, is very different.
Injectors are normally my first suspect.
If I wanted I could stick on the Deka 60lb I had on originally. THats way to much injector for this combo tho and the reason why I went with the 41lb.
Old Jul 2, 2024 | 08:04 AM
91 Z28's Avatar
Shouldn't matter tho. The Terminator will only inject what's needed. I run a 210# injector on my car and I'll never need all that
Old Jul 2, 2024 | 10:47 AM
NicD's Avatar
7 Second Club
But it does matter, and depending on the combo it can just sit there and ride the minimum pulse width at idle and light part throttle cruise areas. Then you can run into injector timing problems with larger injectors if it's not done properly as well. Now whether the average person tuning their car will even realize these things is a whole different matter but I would say that most wouldn't even realize it because "it works". I tell people general rule of thumb is to target around 80% duty cycle for your combo/injector size to eliminate some of these possibilities.
Old Jul 3, 2024 | 01:50 PM
That was my thought or what I've always known/read. You loose the low end tuning with a massively oversized injector. Sure a 210lb/hr on a 5.3 will idle but does it have the same drivability as a properly sized injector. Same thing with a tune which has low res you looking alot of tunability when your jumping 20 KPA between cells when 5kpa gives you much better resolution but makes the table bigger. I'm sure it would work but you would be losing some of that light/part throttle tuning. A 400hp on gas at 80% duty is 28lb, so I'm still way oversized as the 41lb/hr at 80% is enough for 600hp NA.
Old Jul 11, 2024 | 07:08 AM
coryds07,'s Avatar
I have a termX on a 78 vette with a 5.3 and a summit stage 1 8719 high lift cam. Car is running pretty good where I'm driving it on the road to figure out all the little issues. This is not my first TermX LS setup as I have one in a 3rd gen firebird with a 5.3 and a turbo. My issue is at light throttle The engine revs/accelerates just fine through the RPM 3k+ through all gears (700r4). But when I give it more throttle say half or heavier after like 2000-2500rpms it like hesitates and breaks up basically falling on its face till I let out or get above that 3000-3500rpms. I also floored it when this happened and the car felt like it had no power but the car feels faster sometimes depending on when I stab the throttle and depending on the gear I'm in. I did a datalog of one of the runs and Its very weird... looks like its dropping out of closed loop and going to open loop? Then when I come off the throttle the closed loop comes back on. I verified the closed loop is enabled but it wasn't set to a min temp or rpm or anything... the closed loop box was just checked off. I set it to come on after 140*F coolant temp just like my other car. I'm not sure what is causing it to randomly drop out of closed loop but looks like it goes rich and maybe thats whats causing it to break up/hesitate and feel dead like RPMS and power don't climb. I'm not the best with the holley data logs but I attached it if someone could take a look. I also adjusted my closed loop learn values from 50/50 to 15/15 as the tune fuel learn table only shows a 5-8% swing. My timing isn't crazy when the break up is happening like 22-25* If I remember. Its also like my fuel lb/flow drops too like its cutting fuel?
Let me know what you think and what would be a good starting point. Like I said its only on med/heavy throttle and the car really drives fine otherwise (maybe a stall here or there every couple of drives) but I still need to adjust and get the IAC below 40 steps at drive idle.
file won't upload here so I added it to my dropbox. You can download the file here: https://www.dropbox.com/scl/fi/ungco...=ux5bpinp&dl=0
Here is the tune file:
https://www.dropbox.com/scl/fi/41wxy...=puekx47n&dl=0
That VE table is......well needs to be fixed.
Old Jul 11, 2024 | 07:28 AM
91 Z28's Avatar
Thanks tips. That's probably the most ridiculous thing you could say. Did you have anything to add or just it needs fixed??
Old Jul 11, 2024 | 09:03 AM
He's been posting odd crap in some other threads too. I suspect a bot or troll here
Old Jul 11, 2024 | 09:04 AM
91 Z28's Avatar
Yea most likely. His post count is 10
Old Jul 11, 2024 | 11:44 AM
NicD's Avatar
7 Second Club
Finally had a chance to look at this as well, looking at the last zip file that was posted...
- Upgrade your software, it's V1 which was released in 2019 I think and currently it's V3.
- That timing table is very generic and has way too much timing in the low RPM at high load and not enough timing at low/mid/high RPM at low load.
What you described here, "My issue is at light throttle The engine revs/accelerates just fine through the RPM 3k+ through all gears (700r4). But when I give it more throttle say half or heavier after like 2000-2500rpms it like hesitates and breaks up basically falling on its face till I let out or get above that 3000-3500rpms. I also floored it when this happened and the car felt like it had no power but the car feels faster sometimes depending on when I stab the throttle and depending on the gear I'm in. I did a datalog of one of the runs and Its very weird... looks like its dropping out of closed loop and going to open loop? Then when I come off the throttle the closed loop comes back on."
Do you have an instance of this in your last zip file log? Give a time stamp of where if you do. What you are describing is more than likely acceleration enrichment or MAP/TPS rate of change disabling closed loop.
Old Sep 19, 2024 | 10:46 AM
Sorry, I was working on the car and making some changes. Just started driving it again and got a new log and new tune changes. I'm still rocking V1 sorry, I'm not ready to update and start over just yet.
General breakdown of car:
1978 c3 corvette
Stock 2.70 rear gear
255/60r15 copper mastercraft tires (27" tall)
built 700r4 550hp, 12" 2000 stall stock style converter
Unknown year/mileage 5.3 (pre 04 as it has gen 1 rods)
Stock bottom end, HV melling pump
Stock 799 castech heads (no leaks/cracks) Stock MLS style 5.3 head gaskets
Stock rockers, PAC 1218s, 5/16" moly pushrods and Morel 5315 lifters
Summit OG 8719 stage 1 high lift cam. 209 int./217 exh..550/.550 112 lobe
Dorman LS6 intake
Stock 78mm cable TB
42lb LS3 corvette injectors
1 7/8 Long tubes, 3" dual exhaust with Xpipe full length
So I was able to fix what I think was loading up and the car now pulls pretty good through 5500 in gear 1 and 2. 3rd gear is when load is the highest and I'm not sure its tune related and maybe just mechanical load. I was at a light and when WOT (see log attached) tires did not spin but got a smidge of chirp (my 87 firebird with a 5.3 would light up drag radials before boost and that has a 218/228 cam) so I think its gearing and tire. Pulls good up to 5500, shift manually to 2nd got a chirp and kept accelerating. I pulled to 5k (my stock tach is progressively off so I thought I pulled to 5500-6K) and manually shifted to 3rd, car accelerates but not nearly as fast as gear 1 and two. Stock tach starts floating around 100-110 and I let out which was apparently only 4265rpms in the log. The car feels softer in 3rd does that make sense like the tall tire and really tall gear is bogging the motor down causing me to stick around in the 3-4k range where obviously power isn't very high on a mild cam 5.3?
My thoughts are the car has more mechanical leverage with the 1st and 2nd gear rations which allows more leverage to overcome the gears and tire and spin up, then 2nd kicks in which still has more leverage from the trans plus the 3400ish start, then 3rd kills all my leverage and I have the same 3200ish shift return.
  • First: 3.059:1
  • Second: 1.625:1
  • Third: 1.00:1
I pulled alot of timing out of the spark map in the loaded areas and leaned it out as it felt like it was loading up. The car responded better and that dead spot kinda feels like its gone now. Not sure on the HP of this combo but I would suspect 40hp over stock which would put me in the 320-350hp range depending on motor health and maybe thats just what this feels like? I personally think its the gears that are holding me back but gear swaps in these cars (especially the 80-82 aluminum rear) are almost non existent. You can see in the log graph how 3rd gear looks so much longer and drawn out as thats basically how it feels while driving the car. Maybe my expectations where too high for the car with this HP and gearing. Car drives great on the street as I can mostly never need to go into 4th unless I want to on the highway for fuel economy. I still have the cars 383 which I'm going to build up alittle and maybe that would offer enough tq to keep it moving pretty good with the gearing in this thing. Thinking it will be about 380-400hp 5500k peak with a tiny comp cam 218/224 and ported vortec heads but should make 450lbs all day.
I guess any insight would help at this point. The tune and log are attached.
File Type: zip
Old Sep 19, 2024 | 10:50 AM
Tune - wouldn't let me attach before.
Old Sep 19, 2024 | 12:41 PM
  #32
91 Z28's Avatar
You can update firmware without having to start over. Just be sure to save your tune somewhere then update and when you open it again it'll be saved for the updated firmware
Old Sep 24, 2024 | 07:25 AM
  #33
Might do that over the winter then.
Old Sep 24, 2024 | 07:41 AM
  #34
So I decided to just dive in head first. I don't think the tune is perfect but I believe its safe to say if I can rev out in 1st and 2nd that its likely gearing. I pulled the rear out of the car, which looks stamped 2.87 but I counted 2.72 but could have been 2.87. Either way its out and I'm getting 3.73s. When I was pulling the rear I found a few things (of course). The rear feels good (not alot of play and spins smooth) I have the 1350 joints and 3" half shafts. I found that a few had seals broken on the half shaft joints and some broken off and missing which was slinging grease in the plastic end covers and leaking out around the joints. I also found that the batwing brackets were like only 50% welded in on each side. I had to pull the driveshaft and the rear tranny cover so I can swap speedo gears for the 3.73s. Last night I flux welded the batwing brackets as best I could (not alot of room) but they feel much better than before.
  • new rebuilt 3.73 rear coming
  • New solid Spicer 1350 u joints
  • new caps and bolts ( 4 stripped getting them out)
  • 15/42 speedo gears
  • gona also get a new tach board as I tested the speedo and its off 250 at 1.5k, 400 at 3k and 600-700 at 6k (reads high).
The only thing I haven't touched on this car now is the rear trailing arms and the front hubs/ball joints but I believe they were rebuilt and not factory original. I think the new gearing will really wake this car up and if it does I'll likely leave the motor alone and just iron out the tune. I have to pull the front cover for a leak so I was thinking of stepping up to a stage 2 cam like a 218/228 style.
